Results 1 to 6 of 6
Thread: E36 power steering pumps
    Edmonton, Alberta Canada
    96 328is
    So swapped an m3 steering rack into my 96 328is and have gone through 3 stock power steering pumps. Is there a difference between the m3 pumps and non m pumps????
    Sent from my LG-H873 using Tapatalk
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    My 02/98 M3 has this pump 32412227197, the same pump is used on
    •3' E36   (01/1992 — 08/1999)
    •Z3 E36   (04/1996 — 07/2000)
    Part 32412227197 was found on the following E36 vehicles:•3' E36, M3, Convertible, S50, MANUAL, EUR, (BJ91) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Convertible, S50, MANUAL, EUR, (BJ92) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Convertible, S52, AUTO, USA, (BK03) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Convertible, S50, MANUAL, EUR, (BK91) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Convertible, S50, MANUAL, EUR, (BK92) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Convertible, S52, MANUAL, USA, (BK93) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Coupe, S50, AUTO, USA, (BF03) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Coupe, S50, MANUAL, EUR, (BF91) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Coupe, S50, MANUAL, EUR, (BF92) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Coupe, S50, MANUAL, USA, (BF93) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Coupe, S50, MANUAL, EUR, (BF99) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Coupe, S50, MANUAL, EUR, (BG91) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Coupe, S50, MANUAL, EUR, (BG92) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Coupe, S52, MANUAL, USA, (BG93) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Sedan, S50, MANUAL, EUR, (CB91) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Sedan, S50, MANUAL, EUR, (CB92) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Sedan, S52, AUTO, USA, (CD03) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Sedan, S50, MANUAL, EUR, (CD91) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Sedan, S50, MANUAL, EUR, (CD92) : HYDRO STEERING-VANE PUMP/MOUNTING
    •3' E36, M3, Sedan, S52, MANUAL, USA, (CD93) : HYDRO STEERING-VANE PUMP/MOUNTING
    Part 32412227197 was found on the following Z3 vehicles:•Z3 E36, Z3 M, Coupe, S50, EUR, (CM91) : HYDRO STEERING-VANE PUMP/MOUNTING
    •Z3 E36, Z3 M, Coupe, S50, EUR, (CM92) : HYDRO STEERING-VANE PUMP/MOUNTING
    •Z3 E36, Z3 M, Coupe, S52, USA, (CM93) : HYDRO STEERING-VANE PUMP/MOUNTING
    •Z3 E36, Z3 M, Roadster, S50, EUR, (CK91) : HYDRO STEERING-VANE PUMP/MOUNTING
    •Z3 E36, Z3 M, Roadster, S50, EUR, (CK92) : HYDRO STEERING-VANE PUMP/MOUNTING
    •Z3 E36, Z3 M, Roadster, S52, USA, (CK93) : HYDRO STEERING-VANE PUMP/MOUNTING
    That means there is a difference, check with your VIN the correct p/n for your 96 328is
    SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
    http://twrite.org/shogunnew/topmenu.html
    96 328is
    Quote Originally Posted by shogun View Post
    I guess what I'm asking is, is there a capacity difference. I assume the m3 steering rack is larger and the stock e36 pump may be becoming starved or... Can't keep up the right pressure.
    Aug 2009
    Sunnyvale, California
    1984 318i
    The pumps have a metal tag on them indicating operating pressure. Match them up to your rack by part number or pressure. Also make sure you’re running the correct fluid, usually ATF, and that your reservoir filter isn’t clogged.
    Jan 2005
    Japan
    My M3 pumps makes 110 Bar, ZF p/n 7681 955 259 https://minkara.carview.co.jp/userid...ote.aspx#title
    If I remember correct, the non M3 pump makes 90 bar, but check on the metal tag of your car
    96 328is
    Thanks thats what I was looking for thank you guys !!!
  1. E36 WTB: E36 power steering pump
    By cabezzzdb8 in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 09-26-2012, 05:41 PM
  2. E36 E36 Power Steering Pump
    By LOUD e36 in forum Engines, Performance Parts & Software
    Last Post: 02-24-2012, 10:24 AM
  3. E36 WTB: E36 power steering pump
    By das borgen in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 06-13-2011, 09:42 PM
  4. E36 WTB: E36 Power Steering Pump for my 97 M3
    By thedizzle in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 03-27-2011, 11:06 AM
  5. E36 WTB E36 Power Steering Pump
    By vypercat in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 11-17-2010, 11:10 PM
