Results 1 to 5 of 5
Thread: rearend swap
    Oct 2018
    nyc
    bmw 318i
    rearend swap
    can you simply bolt on a 2011 m3 rearend to a 1995 318i sedan? alot of fab work? i installed a v8 engine
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Not even close.
    The driveshaft won't fit.
    The axles won't fit.
    The E92 M3 driveshaft/diff connection is specially balanced.
    The diff mountings will be very different also.
    But hey, it won't be any harder than it was to put a V8 in it. Obviously, you already have access to serious customization equipment and capabilities.
    Chris Powell
    BMWCCA 274412
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Many of us have installed 210mm diffs in E36. There is even a weld-on bracket to put an E32 750il 3.15 LSD in an E36 rear subframe. A fabricator should be able to fit other similar size diffs. People have put Ford 8.8s in E36. Simple, no, but possible, probably and if you can put a V8 in an E36, you should be able to figure out the diff conversion.
    Jun 2002
    E39M5, E500 4WD
    I was surprised to see that the E92 M3 used a fairly normal 210 diff. I thought I'd remembered an electronic lock, but I saw no sign of it in TIS. I did however see that the driveshaft/diff coupling is specially balanced, so attention will need to be paid to this.
    It's worth noting that there's a HUGE difference between the three-pedal car and the dual-clutch car: Normal six speed uses a 3.85 diff, and the dual-clutch uses a 3.15 !!!
    Pbonsalb, doesn't the 318 use smaller axles and hubs? I can't recall...
    Chris Powell
    BMWCCA 274412
    Jun 2005
    New England
    I would assume the OP will convert to E36M3 trailing arms and rear brakes and use E3M3 axles, which have a bigger flange to boltbyonthe 220 diff output stubs. But I don’t know whether the E90M3 diff uses even larger output stubs than the E32 diff that I use. The question then would be whether the older 210 diff output stubs pop into the later diffs. I think I read they do but am not certain. Custom work often takes a lot of research, trial and error and maybe fabrication. That is time and money. It can be fun if you have plenty of both. I try to take the easy way and do what has been done before — and even then it can be a pain.
  1. Rearend swap
    By Collin9311 in forum 1983 - 1991 (E30)
    Last Post: 10-03-2018, 09:34 PM
  2. rearend swap requirements
    By PNWDan in forum 1988 - 1996 (E34)
    Last Post: 08-01-2010, 04:38 PM
  3. M3 engine swap
    By Vok in forum 1991 - 1999 (E36)
    Last Post: 03-06-2001, 10:35 PM
  4. Tranny Swap
    By SAMiAM in forum 1983 - 1991 (E30)
    Last Post: 03-01-2001, 02:17 PM
  5. kidney swap 95 to 97 +? (new b ?)
    By rockstar in forum 1991 - 1999 (E36)
    Last Post: 02-27-2001, 08:49 PM
