Results 1 to 13 of 13
Thread: LOUD HUMMING Noise From The Rear... Low Differential Oil?
    Staten Island, NY
    1998 BMW 528i
    Heya guys,
    Recently I've noticed a VERY LOUD humming noise from the rear of car. It almost unbearable on the highway.
    It does not sound like bearings. I tend to believe my Differential is LOW on Oil.
    Being at 230,936 and not sure if Differential Oil was ever changed, I think I gotta do it ASAP.
    Now, I found few cute DIYs how to do it, but my concern is about what Oil to choose.
    Can I use BMW Differential Oil (P/N 07-51-2-293-972, http://www.ecstuning.com) for the job?
    Thank you in advance,
    siny528i
    BMW CCA 434493
    Dec 2005
    Davenport, IA
    1997 BMW 540i/6, others
    Any synthetic gear oil of the proper weight and type should be fine, there are lots of threads on it. Are there signs it has been leaking?!?
    In any case, if the oil was low, adding more can't hurt but quite likely significant damage has been done that new oil can't save. Differentials while simple devices, have quite small tolerances and go downhill quickly outside of them. Not to mention metal bits in bearings. For sure when you drain the oil look for metal. If your drain pans are quite dirty (like mine) you can drain into something else or even strain it. Also if possible (I don't recall the plug locations off hand) use a light and / or scope and take a look at the ring/pinion gear surfaces through the plug holes and make sure they are not grooved. The faces should still be near mirror smooth I should think even with that miles on a healthy diff.
    Staten Island, NY
    1998 BMW 528i
    Quote Originally Posted by qcdstick View Post
    I dont think there is a damage. At least I hope so.
    Their website says that BMW Differential Oil (P/N 07-51-2-293-972, http://www.ecstuning.com):
    "Not to be used with a limited slip differential"
    What does it mean?
    Am I good to go with it?
    BMW CCA 434493
    Dec 2005
    Davenport, IA
    Quote Originally Posted by siny528i View Post
    What does it mean?
    That oil is fine. As frankly most any 75w90 synthetic gear oil, choose your flavor. Your car should not have a limited slip differential.
    As for your diff, I'm glad you hope it is. But healthy differentials don't make loud noises. At a minimum, some whine under load could merely indicate improper lash which is noisy but not particularly damaging. Unfortunately, assuming you are dealing with a factory BMW differential that used to be quiet (as opposed to one that's been apart and improperly set up by someone after the fact) your lash would have no reason to have changed. That leaves noise from excessive wear, which generally results from improper lubrication, and new oil will not undo that damage. Again, I would highly recommend looking at both the oil that comes out, and if at all possible the surface of the ring / pinion themselves.
    Omaha, NE
    1998 528i 5-spd 102K
    I use Redline fluids.
    I wrote a DIY using "Gravity Fill" (clear tubing + funnel) some 12 years ago.
    Report back what you find after fluid change.
    I thought the rear diff lifespan is some 300K-400K, may be I am wrong...
    http://bimmerboard.com/forums/posts/189240
    Staten Island, NY
    1998 BMW 528i
    Thanks qcdstick!
    Honestly, I do not know when there is a lot of noise or little, because I have nothing to compare with.
    Also the noise that I hear without the rear seat installed.
    In addition, when I drive along a winding road, the noise almost disappears when I am turning right.
    Maybe in the end it's the bearings?
    Thanks again,
    siny528i
    BMW CCA 434493
    Staten Island, NY
    1998 BMW 528i
    Quote Originally Posted by cnn View Post
    Thanks cnn!
    I know. Your DIYs awesome.
    That's exactly what I am going to use.
    I will definitely report back...
    BMW CCA 434493
    Omaha, NE
    Maybe REAR wheel bearings going bad?
    Dec 2005
    Davenport, IA
    Thanks qcdstick!
    Thanks again,
    siny528i
    Diff noise may come and go with the application of power, but shouldn't change based on turning left or right unless you've somehow very badly damaged the planetary gears. Be a good time to change the oil and check it out anyway as a PM. Could easily be a wheel bearing, or something rubbing in the brakes, dust shield... Just i guess depends on what sort of noise it really is, hard to say from here.
    Staten Island, NY
    1998 BMW 528i
    I understand. Maybe this sound will help a little:
    http://cyberforma.com/auto/issues/bm...s/20181011.mp3
    Thanks again,
    siny528i
    BMW CCA 434493
    Dec 2005
    Davenport, IA
    Man, I don't know. That sounds like a single cylinder engine exhaust note more than anything, lol.
    I don't know how fast you were driving, but it's probably a U joint in either the driveshaft or halfshafts. Probably a half shaft if it changes with the suspension loading / unloading.
    May 2013
    Chicago, Illinois
    2000 BMW 528iA
    This is the stuff that Mike Miller, from BMW Roundel magazine Tech Talk column, recommends.
    https://www.amazon.com/dp/B000CPCBF0...v_ov_lig_dp_it
    2000 528i sport
    EMP Stewart water pump
    Dice iPod adapter
    Alpine amplifiers
    MB Quart speakers
    MTX BGE12 subwoofer
    AudioControl EQL equalizer
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    IF its side-related - comes and goes in turns - I like half-shaft/CV or wheel bearings over the diff. Doesn't mean you shouldn't change your diff oil, but I'd get it up in the air, and spin each side and see what you hear and feel, jank around w/ the axles, see if one CV is really boogered up or anything.
    2003 M3CicM6 TiAg
    2014 BMW X1 xDrive28i (hers)
    2008 Audi A3 2.0T DSG (soon to go on the block)
    1999 Cherokee Sport 4L (trailer-hitched in-law-loaner bomber)
    Former:
    1985 Euro 300SL
  1. Loud Humming noise from dash when the A/C is on
    By E39Only in forum 1999+ X5, X6 (E53, E70, E71, F15, F16)
    Last Post: 11-17-2011, 11:42 PM
  2. Loud metal noise from right rear
    By E36Lindberg in forum 1991 - 1999 (E36)
    Last Post: 12-31-2010, 07:05 PM
  3. Grinding in brakes, loud hum noise from the dash
    By BMWROCKSTAR in forum General BMW sponsored by Intercity Lines
    Last Post: 04-20-2010, 04:04 PM
  4. loud clunk noise from the rear
    By Carlo318 in forum 1991 - 1999 (E36)
    Last Post: 09-22-2007, 03:08 AM
  5. Humming noise from driver rear wheel...
    By Shudogg in forum 1991 - 1999 (E36)
    Last Post: 04-06-2006, 08:23 PM
