Results 1 to 8 of 8
Thread: 20mm or 26mm shock pads?
    Houston, Tx
    '78 320i
    RealOEM lists 20 and 26mm shock pads. Which ones would be necessary for H&R Sport/Lowering springs?
    monterey, ca.
    e21, e30 m3. e46 330ci
    you're talking bump stops right?
    do you have bilstein's sports for those springs? they come with internal bumpers, no need for anything else.
    that said, a few years ago i started playing with various bump stops using them as helper springs and was pleasantly surprised at how well it removed what understeer i had left.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
    Houston, Tx
    '78 320i
    I didnt know the sports had internal bumpers, but I was talking about the pads that sandwich the spring.
    Shown here, #2:
    http://www.realoem.com/bmw/enUS/show...diagId=33_0228
    and #4 here
    http://www.realoem.com/bmw/enUS/show...diagId=33_0230
    I guess Damper ring is what they are called.
    Corona California
    79 320/6 81320i 65malibu
    26mm will raise the car ride height 12mm over the 20mm ones.
    Quote Originally Posted by Tom D View Post
    Sweet - this is why bump stops come in so many colors!
    Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
    Houston, Tx
    '78 320i
    Thanks guys, makes sense. Is it the same pad top and bottom as well? RealOEM seems to say so.
    Finally... anyone know if the rubber mounting needs to be replaced? Im assuming if its cracking it has to go.
    #7 here
    https://www.realoem.com/bmw/enUS/sho...diagId=33_0229
    Let me know if I should consider anything else.
    Corona California
    Friend once told me "if you're in there and it's apart - do it all now"
    spring rubber on mine are the same shape top and bottom.
    Question are the new springs open ended like the stock or closed like aftermarket flat ground springs?
    I am assuming the ends look like the stock springs.
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    The open 'rings' are interchangeable. They are however, kind of a bitch to find. Let me know if you do, I need a full set myself that doesn't cost an arm and a leg
    -John
    Houston, Tx
    '78 320i
    I may be misunderstanding here, but H&R springs look to be open, at least without load and from pictures online.
  1. UUC Meyle RSM and Stock E36 M3 Suspension (Springs, Shocks, Pads)
    By Mr. Bevers in forum Suspensions, Springs & Shocks
    Last Post: 12-29-2009, 09:32 AM
  2. WTB: e36 rear shock pads *bay area*
    By dynamik in forum California sponsored by Avus Autosport
    Last Post: 05-04-2008, 05:09 PM
  3. WTB: rear shock pads
    By dynamik in forum BMW Parts Wanted
    Last Post: 05-04-2008, 02:01 AM
  4. July Special - Hawk Pads / Koni Shocks / Fidanza Flywheels
    By bimmer95 in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 07-31-2004, 12:42 PM
  5. Rear Shock Tower Mounts and Brake Pads
    By RayDuck in forum 1991 - 1999 (E36)
    Last Post: 05-16-2001, 10:45 AM
