Results 1 to 1 of 1
Thread: Turner Motorsport N52 3 Stage Intake Manifold w/Software Bundle
    Mar 2001
    Amesbury, Massachusetts
    BMWs and Mini's
    N52 330 Intake Manifold & Software Upgrade
    Shop 3 Stage Intake Manifold Upgrade Here
    The intake manifold from the 2006 E90 330i is a direct, bolt-on upgrade to the other cars with the N52 engine - 128i, 325i, 328i, 528i, and Z4 3.0i. The 330i used BMW's 'high output' N52 engine with a stock 255hp. The other cars used a very similar 3.0-liter engine with only minor changes. The biggest change was with the intake manifold. While these other cars used a single-stage intake manifold, the 330 came with a more advanced 3-stage manifold with electronic valves to direct air to the cylinders that need it most. This kit is a straight-forward bolt-on complete with performance software.
    How The Manifold Makes Power
    The 330 manifold uses two electronic DISA valves (Differential Air Control) to direct incoming air to the cylinders that need it most. The system works based on RPM range to fill each cylinder with as much air as possible while the intake valves are open. This is done by diverting air away from cylinders that have their intake valves closed. With more air volume and fuel adjustments you can extract more power from those cylinders at any given RPM. The standard and medium output N52 engines make do with the old-fashioned single stage system that only works to boost torque in the mid-range. With the additional DISA system you can extract much more power, especially at high RPM. We did our first development on this system in 2006 and it has been one of our top N52 performance upgrades ever since.
    Kit Contents
    Our 330 manifold upgrade includes:
    • E90 330i N52B30H0 intake manifold (new), 11617559523
    • throttle body seal ring, 13547522361
    • crankcase vent hose (used for 325i/525i/Z4 only), 11617559530
    • DISA valve (large), 11617579114
    • DISA valve (small), 11617560538
    • DISA valve mounting screws
    • intake manifold profile gaskets, 11617547242
    • Turner Performance Software (mail-in flash programming)
      The software is done as a reflash of your engine computer. The computer must be sent in to Turner Motorsport for the upgrade. The easiest way to do this is to book your order online, we will contact you with instructions, send us your computer, and we will ship back the upgraded computer and the rest of the kit (you're not charged until items begin shipping). We provide the anti-static bag for your computer. You can use the car with the 330 manifold installed and the stock software but the original 325/328 software will not be optimized for the new manifold.
    Call or email to place the order and we will throw in some Turner swag for free! 800.280.6966 or info@turnermotorsport.com
    Turner Motorsport
    / // Parts and Performance for BMWs
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
  1. Turner Motorsport N52 Intake Boots back In Stock!
    By TurnerMS in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 10-11-2018, 01:16 PM
  2. :: ECS Tuning :: Turner Motorsport N52 Performance Software now available!
    By ECSTuning in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 04-12-2017, 10:50 AM
  3. FS: 3 Stage Intake Manifold Conversion N52
    By BigC in forum Engines, Performance Parts & Software
    Last Post: 07-05-2015, 07:33 PM
  4. CT Stage 2 - E36 M3 Turner Motorsport / Conforti / Euro Intake Kit with 21.5LB Fuel Inje
    By jps1995m3 in forum New York / New Jersey / Connecticut
    Last Post: 03-25-2011, 09:00 AM
  5. E36 Stage 2 - E36 M3 Turner Motorsport / Conforti / Euro Intake Kit with 24LB Fuel Inje
    By jps1995m3 in forum Engines, Performance Parts & Software
    Last Post: 03-25-2011, 08:28 AM
