RM European Auto Parts
Results 1 to 2 of 2
Thread: 850 calipers on 540i ?
    Oct 2018
    Medicine hat canada
    E39 540i
    I looked online and found brand new set of dual piston front caliper for 850s, and they come with the bracket. Did anyone ever tried to equip a 540i with that ? I cant find the blueprint of the bracket to compare..
    Thank
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Both cars use the same rotor size (324 x 30mm). Even if the calipers fit, and even if they use the same master cylinder volumes, the dual piston calipers are not going to make your car stop better, or have any better braking performance.
    If you wanted to actually upgrade your brakes, because you use the car heavily on the race track, you'd do much better swapping to E39 M5 calipers , rotors, and pads. These rotors are 345 x 32 mm, so have much better braking torque and a much bigger heat sink.
    You might need to change the master cylinder and rear brakes to have a matched set - I did not check this for you, so it may or may not be necessary.
    Chris Powell
    BMWCCA 274412
  1. E39 FS: calipers for 540i
    By Bricas45 in forum Brake Kits, Rotors & Pads
    Last Post: 08-26-2011, 11:57 PM
  2. Anyone used OEM 840/850 Calipers on E36?
    By Consonance in forum 1991 - 1999 (E36)
    Last Post: 04-01-2011, 01:18 AM
  3. 1995 850 Calipers on a 92 850
    By 1badzr1 in forum 8 Series (E31)
    Last Post: 02-22-2011, 11:14 PM
  4. WTB: E36 M3 Body Parts/850 Calipers
    By 944CS in forum BMW Parts Wanted
    Last Post: 10-06-2010, 11:05 AM
  5. 850 calipers
    By milenium99 in forum 1988 - 1996 (E34)
    Last Post: 10-05-2009, 07:56 PM
