RM European Auto Parts
Results 1 to 11 of 11
Thread: Ac bypass belt length
    Oct 2018
    Cabot Arkansas
    2006 bmw 525xi
    I have a 2006 BMW 525XI and i am wanting to bypass the ac compressor since the bearing is out. Can anyone tell me what length i would be safe to go with? Time is of the essemce and the parts store is on my way to the car! Ty
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Hmmm, I thought all modern bimmers have a separate belt for the ac compressor. Go to www.realoem.com and enter the last 7 characters of the car’s vin. Hit enter and bookmark the page. Check the engine section.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Nope...one belt, Mark. In fact, there's not many ancillaries to run these days, since water pumps and power steering are both electric now.
    Aboom, I'd highly recommend that you just replace the compressor. You can get a used one cheaply from a salvage yard. No one's going to be able to give you a belt length, because every U.S. 525xi, and probably every one in the world, came with a/c. In fact, since there's an idler pulley between the a/c and the alternator, it's potentially impossible to run without the compressor anyway, because the belt might have to cross directly through the tensioner assembly.
    Here are twelve pages of compressors, at varying prices:
    http://www.car-part.com/cgi-bin/sear...ey=&userPage=8
    Chris Powell
    BMWCCA 274412
    I just looked under the hood of an F15 PHEV. One belt, it's toothed, like a timing belt. The only thing it's for is the starter.
    Water pump, AC compressor are electric. The high voltage stuff takes place of the alternator. If it wasn't for this retarded starter, they wouldn't even have a belt. And, if this starter fails, the e-machine will start the engine.
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    My E39 (2002 I6 M54) has a separate belt just for the A/C compressor. Get some eyes under there to verify your situation.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Two belts good, one belt bad. Or something like that. See “Animal Farm.”
    New York
    1974 2002, 2009 128i
    Quote Originally Posted by MarcoZandrini View Post
    All belts are equal, but some belts are more equal than others.
    Life's tough. It's tougher when you're stupid.
    -John Wayne
    Jun 2002
    E39M5, E500 4WD
    'Comrade,' said Snowball, 'those belts that you are so devoted to are the badge of slavery. Can you not understand that liberty is worth more than belts?'
    Chris Powell
    BMWCCA 274412
    Jun 2002
    E39M5, E500 4WD
    Napoleon reminds me of someone......
    Chris Powell
    BMWCCA 274412
    New York
    This thread has taken an odd turn...not that I'm complaining, mind you.
    -John Wayne
    Jun 2002
    E39M5, E500 4WD
    Quote Originally Posted by 02Pilot View Post
    " I do not understand it. I would not have believed that such things could happen on our forum. It must be due to some fault in ourselves. The solution, as I see it, is to work harder."
    (-Boxer the horse)
    Chris Powell
    BMWCCA 274412
  1. Belt Length On UUC UD Pulleies (Stock = 6x1555)
    By GQ_Style in forum 1992 - 1999 M3 (E36)
    Last Post: 03-07-2006, 07:47 PM
  2. Changing serpentine and AC drive belts
    By Rob111 in forum 1991 - 1999 (E36)
    Last Post: 08-28-2004, 08:40 PM
  3. how to change ac hydraulic belt tensioner?
    By Blazin95Red325i in forum 1991 - 1999 (E36)
    Last Post: 08-22-2004, 08:19 PM
  4. UUC Pulley: Belt Length Math Needed
    Last Post: 01-09-2004, 03:23 PM
  5. Help changing AC fan belt
    By B01001101W in forum 1992 - 1999 M3 (E36)
    Last Post: 09-17-2002, 02:03 PM
