Results 1 to 5 of 5
Thread: M52tub28 into 99 323i
    Oct 2018
    Washington
    1999 323i
    New to BMWs.. got a 323i with a bad m52tub25, found a b28 for sale locally for cheap.. internet research makes the swap sound easy.. bolts right in, may need to use my intake.
    dme, will need flashed... where/who can do this fr what cost?
    If I wanted to do a m54b30... how much more work?
    My car is a 99 323i auto
    Thank you
    Sent from my SM-N960U using Tapatalk
    Oct 2003
    Seattle
    99 M3
    Jun 2012
    New Mexico
    2003 328i
    You can run the stock tune. It'll run just fine. Might run better with a reflash but it's not necessary.
    Your intake is the same as the one used on the 2.8. Identical.
    The B30 is not much more work at all. You may need to swap some sensors. Depends on the production dates of your engine and the donor engine. I just dunked an M52TUB28 into my 03 325 and the sensors were all the same.
    Oct 2018
    Washington
    1999 323i
    Quote Originally Posted by nonturbodan View Post
    As for the 3.0... it would be an m54, correct?
    Is the 54 better then the 52?
    The 3.0 would cost an additional 300$ or so from my engine supplier.
    Jun 2012
    New Mexico
    2003 328i
    That's the only double VANOS 3.0 I'm aware of.
    The 3.0 has a more aggressive intake cam and a little more displacement than the 2.8. Other than that, same head and valves. One advantage the 2.5 and 2.8 M52TU engines have is the oil control rings. The M54B25 and B30 rings seem much more prone to sticking and increased oil consumption. My experience with the M52TUB28 in particular is that it goes 15k between changes without using a drop. I've owned two M54 engines, one 2.5 and one 3.0 and both liked to use oil.
  1. possible switch to a '99 323is
    By kherber540 in forum 1991 - 1999 (E36)
    Last Post: 10-16-2002, 11:59 PM
  2. S/T Charging info. needed for '99 323is
    By M3WANABE in forum Forced Induction
    Last Post: 10-03-2002, 10:13 AM
  3. 99 323IS Sales Brochure wanted
    By TSeck in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-11-2002, 03:53 PM
  4. Need help with intake for 99 323i please...
    By madsedan in forum 1999 - 2006 (E46)
    Last Post: 05-08-2002, 10:11 AM
  5. Noah cover 99 323IS needed.
    Last Post: 04-26-2002, 09:58 PM
