Results 1 to 17 of 17
Thread: E31 Battery charge
    Oct 2018
    San Jose
    1991 BMW 850i
    E31 Battery charge
    Hi, I'm new to this community and I just bought my E31 today.
    The previous owner told me that i had to plug my car into an outlet so that the battery doesn't die.
    Does anyone else do this, or is it just me?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E31 forum
    Jan 2016
    Ca
    2001 525it
    We had a custmer with the two battery's we ended up using two battery tenders now it's always ready to go, also we installed agm battery's
    Nov 2014
    Seattle
    1985 M635CSI, 1992 850i
    Yes, a lot of E31 owners use battery tenders - which indeed plug into the wall outlet.
    Mine is under the hood and connects into the posts under there.
    Oct 2018
    San Jose
    1991 BMW 850i
    Quote Originally Posted by Stantz View Post
    Is it possible to do a single battery conversion?
    How will it effect the car?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    You can use a single Ctek MXS 5.0 on either battery (or connected to the jump-start points under the hood) and both batteries will be successfully charged - you don't need two chargers as the batteries are connected in parallel.
    More information on battery drain here:
    https://www.meeknet.co.uk/e31/E31_Ba...iagnostics.htm
    Information on changing batteries safely here:
    https://www.meeknet.co.uk/e31/E31_Ba...eplacement.htm
    My BMW Repair YouTube Channel
    Jan 2014
    London, UK
    Bmw 840
    Listen to you going all American Its not under the hood, its under the bonnet
    1998 e31 840ci Sport, Individual. 2008 Aston Martin DB9. 2016 4.4 SDV8 Range Rover Vogue.
    1959 Triumph Bonneville, 1969 T120R Triumph Bonneville, 1975 T160 Triumph Trident, 1990 Harley Davidson Fat Bot Grey Ghost, 2009 Triumph Bonneville 50th Anniversary model. 2014 Suzuki Gladius.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    When in Rome, do as the Roman's do!
    Jan 2014
    London, UK
    Bmw 840
    Your not in Rome though, you are in Hampshire UK
    Oct 2018
    San Jose
    1991 BMW 850i
    Quote Originally Posted by rodneyngo View Post
    What is the best oil for my e31? I live in california, san jose and i was wondering if 10w40 mobil 1 would be fine.
    May 2013
    Stamford, CT
    1991 BMW 850i
    If this is your daily driver, you probably don't need to keep it on a tender (but still good to do every once and while). I do it when I don't drive it for a while during the summer, and through most of the winter (I'm in the northeast and don't drive it in the winter). The car is kept outside under a cover, so it's kind of a pain to run an extension cord across the driveway. In the winter, I park it close to an outlet and keep it plugged in.
    For oil, I that is what I used. But it does depend on your driving. I struggle to put 500 miles on a year, so wasn't that concerned about viscosity, just wanted synthetic.
    My Cars - 1991 BMW 850i - mine for fun, 1993 Saab 900c - mine for fun, 2008 Lexus is250 - my daily driver, 2003 Dodge Durango - my wife's, 1994 Acura Legend - gave it to kid
    Sep 2018
    Lodi, NJ
    2012 BMW 5 Series
    I have been using the black and decker charger which is a lot cheaper than Ctek and it is working fine. There is a how to on this here.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    For battery drain, GM needs to be removed and rebuilt or RM module needs to be replaced.
    Oil is a long discussion, but I like Motul Xcess 5W40
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    I've tried quite a few oils in the V8, but have settled on this one because of the reduction in lifter noise:
    https://www.meeknet.co.uk/e31/BMW_E3...ter_Change.htm
    Sep 2018
    Belgium
    1990 850i and 1970 2800C
    i had battery drain with the oem alarm installation. When that was removed , batterys stayed OK ! I even installed now a battery switch to be safe during long parking inside . Switch is in the trunk , where the batterys - connect to the cars body. I only may not forget to not close the trunk...so i have a towel in there , to use to prevent the lock working with the trunk "nearly" closed.
    And yes, they are in parallel... so if one battery go's bad it pulls the other also down.
    Jun 2012
    Mundelein, IL
    840Ci/6 528iT Europa TCS
    I also use conventional oil in my 840. I use Castrol GTX 20w50. I don't drive the car in winter so I don't really car about the low end of the viscosity. I find it interesting that the owners manual also recommends 15w40 which is mostly a weight used for diesel engines. I have considered using Shell Rotella T4 15w40 but only if I can't find the Castrol 20w50. So far I have been able to find it pretty reasonably.
    I also feel pretty safe using the 20w50 on a day like today when I was red lining the motor while driving around like a "menace to society" passing anything and everything. Just sayin'.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Exide Extreme L5/49/H8 batteries at, believe it or not, Home Depot for $119
    900 Cold Cranking Amps
    1080 Cranking Amps
    180min Reserve Capacity @ 25 Amps
    I just picked up 4 of them.
    '91 850i 6sp (mint) (sold)
  1. BMW E31 Battery (ies) trickle charging
    By Mmrmm in forum 8 Series (E31)
    Last Post: 08-08-2015, 10:50 AM
  2. Battery charging questions!
    By M3C in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-24-2004, 05:18 PM
  3. Battery charging questions!
    By M3C in forum 1992 - 1999 M3 (E36)
    Last Post: 09-24-2004, 12:39 PM
  4. BMW Battery Charging System
    By RicN in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-07-2003, 12:20 PM
  5. Battery Charge Question
    By Garett E. in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-05-2003, 09:56 AM
