RM European Auto Parts
Results 1 to 14 of 14
Thread: don't trust it
    Joppa, Md
    99 M Coupe,04 K1200rs
    don't trust it
    It cranked fine but wouldn't fire up a few times on me lately, cam sensor code only one coming up, bought 3 Chinese specials, from $10 to $90, still got a cel,but ran fine, got a BMW sensor, haven't installed it yet, changed fuel pump relay and dme relay,am carrying 2 new spare relays, will a failing pump show any codes?,would I have to read them when it won't start?Does a good reader show past non-start history/reason?I was ready to call my son to bring the tow bar to my last race, but it started after 20 minutes,and ran fine 90 miles home.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    On nothing but a hunch, Bob...fuel pump.
    I forget, does the S52 have a schrader valve on the fuel rail? I have a spare fuel pressure gauge...I'll loan it to you if you'd like.
    You know I'd never buy a Chinese sensor....but yet, I do not believe that this will stop your engine from starting.
    Chris Powell
    BMWCCA 274412
    May 2012
    Connecticut
    4 e36 / 1 e30 / 1 e39
    S52 should have a Schrader Valve to check fuel pressure
    Jun 2002
    E39M5, E500 4WD
    Bob, if you'd like to borrow my spare gauge, just PM me with your address, I'll mail it out to you.
    Chris Powell
    BMWCCA 274412
    Joppa, Md
    will a failing pump show lower pressure all the time?, I'll assume you have the same distain for aftermarket pumps? lol, I'll rig up a gauge
    Jun 2002
    E39M5, E500 4WD
    The Z3's fuel pump is very ugly to change. It lives behind the passenger seat, and the entrance is at least a foot above the floor. First step is cutting the perforated carpet. If the tank is more than half full, you're very likely to end up with gas on your carpets. Just saying....
    You need to have the gauge hooked up when the symptom is manifesting, in order to know whether that's your issue, or not.
    I don't dislike good aftermarket fuel pumps. What I personally don't like is having to disassemble and reassemble the fuel pump unit, with the hardened old plastic hoses and connectors. Unless a special high-volume pump is needed for extreme race duty with a huge turbocharged engine, I would absolutely buy a new, complete VDO unit, and a new o-ring.....IF THE PUMP IS BAD.
    I wouldn't assume this is the case though. Wait 'til the next time it fails to start, and see how much pressure is at the schrader valve.
    Chris Powell
    BMWCCA 274412
    Jul 2004
    Houston, TX
    36 Cylinders
    Oftentimes crankshaft position sensors fail on E36 and never throw a code. Car just stops running. Check rpm when cranking. No rpm detected = bad crankshaft position sensor. It was quite common.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Joppa, Md
    I did replace it,as well, got both sensor codes one time only.
    Jun 2002
    E39M5, E500 4WD
    Chinese, or OEM ?
    Chris Powell
    BMWCCA 274412
    Oct 2017
    Cocoa Beach Florida
    2001 BMW 740i
    What a Guy!
    I'm always amazed at your willingness to go the extra mile without any strings attached. A rare trait indeed.
    Joppa, Md
    Nationalist China(Taiwan), and my new BMW dealer part cam sensor is from Slovakia!,and I still have a pending code on this one,arrgh!, it cost 13 times more than a Chinese one.I ordered a new original equip. pump, but tomorrow I have an AX 80 miles away, I have access to the pump,and plan on my old MG/Lucas system for coaxing a recalcitrant pump to life, if needed, a hammer tap.
    Jun 2002
    E39M5, E500 4WD
    Slovakia is fine. All of Europe is fine.
    Jerry, thanks. Seriously, I'm just here to help....and of course, I owe everyone a little extra because I'm such a butthole sometimes.
    Bob, peel back the rubber boot at the cam sensor plug....do you see any burned insulation?
    Chris Powell
    BMWCCA 274412
    Nov 2008
    Eugene, Oregon
    e30, e34, e36, Cherokee
    Always listen to Chris, hes helped me several times in the past and albeit "butthole" but I in stubbornness, he knows his BMW's.
    That being said I learned to only keep European sensors on European cars, Japanese on Japanese cars, American on American, ect. STICK WITH OEM for electronics, its really important the tolerances be right for the ecm.
    I quite quite the quaffle with a e46 and 2 after market crank sensors til ordered oem from fcp euro... Sometimes it ran, sometimes not.
    Slowly climbing the ladder. But never reach the top.
    Click Car 4 Build!
    '86 325es-Turbo m30!
    '94 325iA-Clean DD
    '94 530i
    -6 Spd swp
    '89 Cherokee 4x4-4.7L stroker
    '97 Eclipse Spyder-4g64/63 stroker Turbo.
    '89 535is-RIP 2020, engine now in e30!
    '84 318is-RIP 2016.
    '89 535iA-Parted 2012
    94' 530iA-RIP 2004, engine in new 530i
    '78 530ia-first car RIP 2005
    Joppa, Md
    Quote Originally Posted by darknezz7 View Post
    My coupe has a "Lucas" brake booster, can the prince of darkness screw up a mechanical part?
  1. who do you trust
    By gr8330 in forum 1983 - 1991 (E30)
    Last Post: 11-05-2002, 08:02 PM
  2. Favorite/ Most Trusted Car Mag
    By ///MDriver in forum Off-Topic
    Last Post: 09-19-2002, 11:36 AM
  3. 95 M3 Paint Job. Who to trust??
    By chrisboiii in forum 1991 - 1999 (E36)
    Last Post: 08-17-2002, 10:57 PM
  4. Trust No One!
    By M3D in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-30-2001, 04:47 PM
  5. Turner Motorsports is NOT to be trusted!!!READ
    By MMTuning in forum 1992 - 1999 M3 (E36)
    Last Post: 03-23-2001, 10:01 AM
