Results 1 to 21 of 21
Thread: oil filter canister
    Oct 2012
    Penna
    2000 z3
    oil filter canister
    I have been checking around for a socket to remove the oil filter canister cap on a 2000 z3 convertible. I think it is an 86mm but I can never get any clear info on this. As a matter of fact it seems any info I need on this vehicle never seems to be correct, always seem to get different answers and nothing consistent. If someone knows FOR SURE I would appreciate it. Thanks, Chuter
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    I think you will need to tell us which engine you have before anyone can answer your question "FOR SURE".
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Dec 2013
    Chicagoland area
    EXOTICS
    Enter your vehicle VIN# here:https://www.realoem.com/bmw/select.do
    Oct 2012
    Penna
    2000 z3
    I'm sorry, It is 2.5. I believe m52 engine. Thanks Chuter
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by MIKYZZ4 View Post
    That gets him this far:
    https://www.realoem.com/bmw/enUS/sel...es=Z3&body=Roa
    It does not tell him what engine he has.
    To tell his engine, he should put the last 7 characters into:
    http://bimmer.work
    BMW MOA 696, BMW CCA 1405
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    I thought all the oil filter cap nuts were 36mm.
    I got this one:
    https://www.ecstuning.com/b-schwaben...8-drive/oc-03/
    Works on my M Roadster and 2.8 Z3. If you scroll down to the cars it fits, "All" is listed under BMW.
    Nathan in Denver
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Sorry. Mine was a 99 2.5 and it used a 36mm.
    Oct 2012
    Penna
    2000 z3
    The canister has a nut at the top, it is 36mm. It also has flat spots lower on the cap. I wanted a socket that would fit these flats. I tried to measure the diameter o f the cap from flat to flat but my digital calipers decided to stop working. Am I looking for the wrong thing? Thanks, Chuter
    Dec 2013
    Chicagoland area
    EXOTICS
    Quote Originally Posted by Vintage42 View Post
    http://bimmer.work
    Yes, a little more work,
    but you can take the BMW engine part# revealed by realoem,
    Google it-that will reveal the engine size.
    Btw, bimmer.work is an excellent VIN check site.
    Oct 2012
    Penna
    2000 z3
    I know that it is a 2.5. Is that not an m52? , Chuter
    Dec 2013
    Chicagoland area
    EXOTICS
    I just ran my VIN# on realoem- reveals all that info!
    Oct 2012
    Penna
    2000 z3
    Soooooooo. What wrench do I need to remove the cap. I want to use the lower flats on the cap, not the 36mm nut. Chuter
    Oct 2012
    Penna
    2000 z3
    Ok khammack, Now do you see what I mean by getting info that I cannot use? All I wanted was a wrench and after 6 hours I'm right where I started. Hope this comment doesn't pi$$ anyone off. It's all good. Thank You all, Chuter
    Jul 2004
    Houston, TX
    36 Cylinders
    That's because the proper thing to do is use the 36mm
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2012
    Penna
    2000 z3
    I think you may be correct. I think I may be asking for something that does not exist. I will do as you say but at some point in time I will find what I need. Thank You all, Chuter
    Aug 2012
    Kansas
    Ahh. I see what after now. Yes use the 36mm nut. My 2010 X3 doesn't have a nut on the 3.0 and takes a filter cap socket like you're referencing but I'm not sure what size you'd need since I never removed it that way on the Z3
    Oct 2012
    Penna
    2000 z3
    Thank you for understanding what I am looking for. Chuter
    Dec 2013
    Chicagoland area
    EXOTICS
    Dec 2005
    Sarasota, FL
    98 M Roadster
    You want a 36mm. The M54B25 oil cap has flats at the top for a 36mm hex socket for service and flats around the base for either aesthetics or factory assembly. Some other BMW models do have caps that use the very large lower flats for removal, but they do no have the upper 36mm hex. The tools made for the lower flats will not work for you as they do not clear the added height of the upper hex. Just use the 36mm.
    Joppa, Md
    99 M Coupe,04 K1200rs
    A big ass metric crescent wrench should work!
    Dec 2013
    Chicagoland area
    EXOTICS
    36MM and be done with it!
  1. custom oil filter canister cover?
    By nailheader in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-14-2005, 04:26 PM
  2. oil seeping from oil filter canister (m50)
    By shragon in forum 1996 - 2003 (E39)
    Last Post: 11-17-2004, 04:32 PM
  3. Oil filter canister?
    By NLR in forum 1992 - 1999 M3 (E36)
    Last Post: 05-09-2003, 01:59 AM
  4. 735i Oil Filter Canister Valve
    By CrowBar in forum 1988 - 1994 (E32)
    Last Post: 01-22-2002, 12:20 PM
  5. 735i Oil Filter Canister Valve
    Last Post: 01-21-2002, 04:26 PM
