Results 1 to 19 of 19
Thread: Help with DTC's
    USA
    93' C38 S50, 00' GT28 A4
    Help with DTC's
    I just scanned my car with PA Soft and came back with this. Do my O2 sensors definitely need to be replaced?
    93 E36 S50 c38 stg2
    00 B5 A4 GT2871r
    01 E46 325i - 343,782 (Stolen 3/2021) RIP
    2019 WRX
    auto->manual conversion crew / bf.c motor swap crew
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Look at the description. Check your wiring for damage before thinking about replacing the sensors.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Jun 2012
    New Mexico
    2003 328i
    Faults not currently present. I would clear them and forget about it unless that CEL comes on.
    USA
    Quote Originally Posted by nonturbodan View Post
    I did and it comes back after 10-15 miles.
    93 E36 S50 c38 stg2
    00 B5 A4 GT2871r
    2019 WRX
    Jun 2012
    New Mexico
    2003 328i
    Sounds like a wiring issue then. The leads for the oxygen sensors are very long, especially the post cat sensors. Lots of wire susceptible to damage. I would look for wires contacting the exhaust, melting and shorting that way.
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Codes 227 and 228 are rich mixture. Most likely cause is bad maf. Excessive fuel pressure is less likely but possible. Exhaust temperature sensors (egt) are not used on USA cars. I believe some euro cars had them. There is actually a light in the cluster for exhaust temp warning that is not used here either. You can see it with a flashlight. Ignore the egt sensor faults. Your issue is probably the maf.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    USA
    Quote Originally Posted by randy72877 View Post
    I just replaced the fuel pump on the car last week. I'm going to clean the MAF tomorrow before I try anything else. Thanks!
    93 E36 S50 c38 stg2
    00 B5 A4 GT2871r
    2019 WRX
    USA
    I recorded these values driving around my neighborhood. My research tells me the MAF value is way off.
    93 E36 S50 c38 stg2
    00 B5 A4 GT2871r
    2019 WRX
    Jul 2004
    Houston, TX
    36 Cylinders
    Does that self test error come back every time too?
    That's a code that can indicate dme failure or possibly someone messed with the flash.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jul 2004
    Houston, TX
    36 Cylinders
    MAF Value isn't terrible, seems to be doing the right thing.
    Not sure where 227&228 came from above.. there are no 227&228 errors in screenshot.
    -Abel
    Mar 2015
    west chicago il
    See 4th post.
    Jul 2004
    Houston, TX
    36 Cylinders
    See 4th post.
    Oddly the picture link there doesn't show up for me, only when I use that post in quote.
    so here is the link
    https://i.imgur.com/VSSDJ9P.jpg
    -Abel
    Jul 2004
    Houston, TX
    36 Cylinders
    Still doesn't actually show a picture.
    "The image cannot be displayed because it contains errors."
    But I believe you.
    -Abel
    USA
    But I believe you.
    Thanks for all of the help so far!
    93 E36 S50 c38 stg2
    00 B5 A4 GT2871r
    2019 WRX
    Jul 2004
    Houston, TX
    36 Cylinders
    Did you clear errors? Does that ecu self test error come back every time?
    -Abel
    USA
    When I clear the codes, the yellow codes come back immediately. The red faults take 10-15 miles to reappear.
    93 E36 S50 c38 stg2
    00 B5 A4 GT2871r
    2019 WRX
    Jul 2004
    Houston, TX
    36 Cylinders
    So then if the ECU internal error comes back constantly, you need another DME. It is failing an internal check. I wouldn't bother changing any other sensors until that part is resolved.
    I can help with a dme swap, if needed. It's not terrible if you know how.
    -Abel
    USA
    I've replaced the ECU in the E36's before. If its a similar job it shouldn't be too much of a hassle. The thing is, if it weren't for the CEL being illuminated, I wouldn't know anything was off with the car. The performance hasn't changed and gas mileage is as good as it ever was. Would you still replace the ECU if this were the case with your vehicle? I'm seeing E46 DME's on ebay for well under $100 but who knows if they're functional. Would I have to take it to the dealer to get it coded to my vehicle or is that something I can do with the PA Soft 1.4?
    93 E36 S50 c38 stg2
    00 B5 A4 GT2871r
    2019 WRX
    Jul 2004
    Houston, TX
    36 Cylinders
    A used E46 dme has to be virginized before it can be synced to the ews. It is not in any way as simple as e36 at all. It uses a static ews code as well as a rolling code. Not a PASoft job.
    You can find them under $50 sometimes, but there's a process to get it working with your ews system. All the ones I've ever bought (20+) were fine.
    -Abel
  1. ASC and ABS Code help: "CORE DTC" P00BF, B1FF9, B11EE
    By garf in forum 1991 - 1999 (E36)
    Last Post: 04-28-2016, 12:57 AM
  2. New Girl needs help with DTC (P17E1)
    By cally745i in forum 2002 - 2008 (E65, E66)
    Last Post: 12-26-2011, 02:09 PM
  3. Please help with DTCs!
    By heifetz17 in forum 1995 - 2001 (E38)
    Last Post: 08-10-2009, 07:56 PM
  4. DTC P0171 & P0174 help
    By dunes in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-02-2007, 06:39 AM
  5. Airbag DTC Help needed code OB
    By mikealfano in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-11-2006, 11:18 PM
