VRSF High Flow Upgraded Air Intake Kit 15-18 BMW M3 & M4 F80 F82 S55
For your 2015+ BMW M3 & M4 with the S55 Engine
The VRSF High Flow Air Intake upgrade for your M3/M4 replaces your restrictive OEM intake with a high flow design. This kit was designed to retain the OEM cold air ducting and eliminates the upper portion of the air intake which has been proven to be incredibly restrictive, especially in the upper RPM range. The result is a gain of up to 14whp in the mid to upper RPM range when increasing boost above OEM levels. Our high flow inverted S&B cleanable filters offer increased flow along with a more aggressive intake sound. This upgrade also offers improved turbo spool as well as an increase in transient response.
We include everything necessary to replace your OEM intake including couplers, clamps and filters. This kit is completely reversible and does not require any permanent modification. This kit is available in both polished and wrinkle black powdercoated finish.
Features:
  • Available in polished or powdercoated black aluminum piping.
  • Designed for a quick and easy install.
  • Increased spool, transient response and induction sound.
  • S&B high flow 8 ply cotton cleanable filters.
  • CNC flanges made from high quality billet aluminum.
  • Mandrel bent high flow 3" aluminum tubing.
  • Includes everything necessary to upgrade from factory intake.
  • Lifetime warranty.
This item fits the following BMWs:
  • 2014 - 2018 F80/F82 BMW M3 & M4
  • 2017 - 2018 F80/F82 BMW M4 GTS
  • 2018+ F82 BMW M2 Competition (S55 Only)
