Results 1 to 5 of 5
Thread: Tire question
    Oct 2018
    Washington
    1998 M3
    Tire question
    I have a 1998 m3 which comes stock with 225’s in the front and 245’s in the rear. For some reason the previous owner decided to put 225’s in the rear as well. How big of a difference does this make when it comes to handling in dry and wet conditions?
    Jun 2013
    Bellevue wa
    1998 bmw m3 sedan
    Quote Originally Posted by ethanstewart23 View Post
    About 20mm... jk, if you aren’t pushing it it’s fine but if it was me I would get new tires.
    I had a winter setup with 225/45 squared and it felt good but it was also in the winter.
    98 M3 sedan
    Aug 2013
    1999 BMW M3 Coupe
    On the street, very little. Not unless you drive in snow/ice and they are winter tires. Even in the rain, 225's should stay planted as long as they are decent tires with plenty of tread and you're not driving like a maniac.
    That said, assuming you still have the OEM wheels, get the proper size tires when you decide to buy a new set.
    Oct 2003
    Seattle
    99 M3
    Tire question
    IF there are 8 1/2 inch wide rear wheels, 225/45-17 will be pretty stretched.
    The 1995M3 LWT was fit with staggered 7 1/2” X 17” and 8 1/2” X 17” Style 24s shod in 235/40-17’s all around.
    The same tire all around balances the grip front - to - rear as originally intended by BMW, less tendency to understeer and more prone to throttle oversteer. This is a trait that was “corrected” in 1996 with different spindles, FLCAs, stiffer front springs, and 8 1/2” rear wheels with 245/40-17 tires in the rear.
    For what it is worth, I run 225/45-17 snow tires all around on 7 1/2” wheels all around and have tracked them in March in Seattle.
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    You can find these charts everywhere and each tire manufacturer has their own but this one is not bad.
    BMW put 235 on 7.5" rims all around for the '95 and went with the rear 245 on 8.5" wheels for the later E36M3s to temper the little bit of oversteer, especially if you're prone to using too much brake in the turns. The 235 all around make a nice package. Good handling and the little oversteer is easily handled.
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
  1. tampaturbom3 & tire question combo msg
    By EricH in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-02-2002, 06:43 PM
  2. Tire question for those with factory staggerd wheels
    By BMWM3some in forum 1992 - 1999 M3 (E36)
    Last Post: 11-19-2001, 02:25 PM
  3. Tire Question
    By perot in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-17-2001, 12:08 PM
  4. Small leak in tire question?
    By dgm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-04-2001, 02:20 PM
  5. Tire Questions!
    By BMWFAN in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-27-2001, 12:01 AM
