SOLD
This clutch setup has about 2000 miles on it, only a few passes at the drag strip. It was recently sent back to quartermaster and they deemed the discs within service limit (.246 and .243; they start at .250). There was wear on the pressure plate fingers so the cover was rebuilt. The throw out bearing is the proper radius-face tilton bearing for the clutch setup. The bearing was turned down to be shorter so that it will fit the application without any modification to the clutch fork. The flex disc and flywheel bolts are included so this setup is complete and ready to bolt up.
This clutch will fit any 5-speed m/s5x. I highly recommend using a 540i slave with this clutch since it is like an on/off switch otherwise. I have one with 2k miles on it that I can include for a little extra.
$550 shipped
See google drive link for pictures. Let me know if you have any questions.
https://drive.google.com/drive/folde...gj?usp=sharing
I think I have a buyer for you
