Results 1 to 4 of 4
Thread: Intermittent Driver's Side Window - solved
    Loveland, Colorado USA
    1993 740i
    '93 740i
    My driver's side window is operating intermittently. It will work for a couple of days without issue, then not work for a couple of days...usually when I pull up to the drive-thru, lol.
    I can sometimes get it to function by opening and closing the door, although not always. I have Shogun's auto up/down module installed (and have for 5 years without issue).
    Questions:
    Is the window supposed to open and close when the door is open? My window has never operated when the door is open, not sure if this is a standard feature or if I'm just special.
    I am suspecting either a break in the wiring or a motor that has a dead spot that will get moved just enough when closing the door to get the motor to function.
    Anyone have a similar experience and any advice before I dig into it this week?
    Thanks much.
    Greg
    '93 740i - Mine
    '13 Range Rover Sport - Hers
    '08 Land Rover LR2 - Hers
    '96 328i - Son's
    '97 328ic - Daughter's
    '87 944 Turbo - Mistress
    '74 Alfa Romeo Spider - Italian Mistress
    Northern Colorado, USA
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I suspect a broken wire loom which still has contact sometimes. Main suspect is always the driver door side where the wire loom goes from the A-pillar into the door, as this door is mainly used
    Here is a detailed pdf for the repair, 1 MB, but to download it you might have to register first http://www.7-forum.com/forum/showthr...t=118598&page=
    another one with pics : click here in the index Kabelbruch Tuer links hinten = broken wire loom door rear left http://bmwe32.pagaduan.org/
    http://www.bimmerboard.com/forums/posts/649628
    on my website, see pics, scroll down http://twrite.org/shogunnew/check/el...Wire_failures_
    1993 740i
    Shogun was correct, there was a break in the power wire to the window motor. Once I pulled back the rubber cover between the door and the body the break was obvious. I soldered in a short piece of wire to relieve the stress on the wire. Not much room to work but I managed to get my soldering iron in there without melting any other wires. Nice to be able to go through a drive-thru again, lol.
    Thanks as always Shogun for your invaluable help.
    '93 740i - Mine
    '96 328i - Son's
    Jan 2005
    Japan
    Here a pic of such a typical fault, usually on driver door side between A-pillar and door http://twrite.org/shogunnew/files/doorwire.jpg
  1. 750iL driver's side window stopped - SOLVED
    By fischp in forum 1988 - 1994 (E32)
    Last Post: 09-12-2014, 07:49 PM
  2. HELP! driver's side window prob! cannot find in search
    By Reck1ess in forum 1991 - 1999 (E36)
    Last Post: 06-15-2003, 03:21 PM
  3. Driver's Side window/door lock/domw light BROKE
    By eightyseven in forum 1991 - 1999 (E36)
    Last Post: 04-09-2003, 10:07 PM
  4. Driver's side window and door handled F'd up
    By edacosta in forum 1991 - 1999 (E36)
    Last Post: 07-02-2002, 06:41 PM
  5. My driver's side window motor died...
    By Andre325i in forum 1991 - 1999 (E36)
    Last Post: 03-31-2002, 08:25 PM
