Results 1 to 3 of 3
Thread: 6 speed options
    Nov 2017
    Hungary
    1984 BMW E28 535i
    6 speed options
    Hey folks. Looking for a 6 speed tranny for an M50. Will any box fit from M52 M54 engines? Cheers.
    1996 Orientbraun BMW E34 532i Touring
    STANCE | WORKS
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Yes, also S54, and possibly the N-engines N52-N55. Clutch and flywheel will fit natively from some of these, but I'm not sure about the N motors - IIRC one of them had a mid-production change from a 6-bolt flywheel to an 8-bolt. Trans codes are GS6-17GZ (N53), GS6-37BZ (M54, N52), GS6-45BZ (N55), and GS6-53BZ (N54).
    Also, I'm 95% sure (you should research to confirm) that any of the diesel transmissions - 320/520d, 325/525d, maybe others - will fit as well. I've done some homework on these because some of them have extra-tall gearing and I want that for a diesel swap:
    GS6-37DZ - three different sources of data give three different gear ratios. One of them says it's double-overdrive (5th is 0.8 and 6th is 0.66). There are some variations for all the transmissions here, but AFAIK this is the only trans with claimed major differences within the same basic name.
    GS6-45DZ - "Efficient Dynamics" transmission. Double-overdrive without a doubt, but seems expensive, has first- and reverse-gear problems, and is dry-sump (I don't have details). Came behind N47D20O1 (leave it to modern BMW to make a code where a letter O follows a zero )
    GS6-53DZ - came with M57 and N57
    By the way, if you, being in the magical kingdom of Europe, have access to the diesel transmissions and could help me find a -37DZ with double-overdrive, I'd be most grateful, and willing to help you source any US-market stuff you might want.
    Nov 2017
    Hungary
    1984 BMW E28 535i
    Thanks a lot.
    I'm in EU. I'll give you my Facebook profile in private message for easy communication, if you still need the tranny.
    STANCE | WORKS
  1. Check Control "SPEED" option on Instrument cluster
    By Guywithe34 in forum 1988 - 1996 (E34)
    Last Post: 04-26-2011, 09:09 PM
  2. 2002 Dinan BMW M3, Titanium Silver, NAV, 6-speed, All options, low miles, immaculate
    By AATurboM3forme in forum BMW Cars For Sale / Wanted
    Last Post: 06-13-2005, 06:25 PM
  3. 2002.5 Jet Black/Imola Red 6-speed M3 with NAVIGATION, Every Option including 19's!
    Last Post: 05-19-2005, 06:56 PM
  4. '07 M5 will have a 6 speed tranny as an option
    By Dwayne in forum 1988 - 1996 (E34)
    Last Post: 04-08-2005, 06:21 PM
  5. bmw 540 6 speed wheel option
    By Dj Waffelz in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-07-2003, 04:01 PM
