Page 5 of 10 FirstFirst 12345678910 LastLast
Results 101 to 125 of 233
Thread: P0011 code
  1. #101
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    That's unfortunate. Hard to see from your pic (bad internet connection where I'm at) is it just the rings that are busted or the rings and the ends of the cam where the rings fit into?
    I replied to your PM.
    Yeah for sure the cam end slots are destroyed, thats his issue...
    I also replied to PM...
    Quote Originally Posted by kouks View Post
    ^ Thanks Purple, yes, it was an 01 740iL and they are coated. I also got the solenoids but I think I’ll get new ones just to have piece of mind.
    Yep - the solenoids are $$$ new be prepared for that, and, they DON'T tend to fail, so I'd lean towards running the used ones but leave it to you. As long as you don't screw one up like I did they seem to last forever.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  2. #102
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    SUCCESS!!
    It sure was that broken camshaft oil seal. Replaced both VANOS solenoids also with used ones from the JY car. Runs nice and smooth. My son has a smile back on his face.
    I do have one issue though.
    Shortly after running it I got a P0343 code, Camshaft Position Sensor (CPS) Bank 1.
    Checked all connections and no problems. Both CPS are new.
    Replaced both CPS with the old ones, same P0343
    Swapped Bank 1 and 2, same P0343
    Runs fine for now, takes about 6-7 turns to start rather than the usual 2-3 turns, but told my boy keep driving it until I found the wiring problem. Checked fuses in glovebox and all seemed good.
  3. #103
    IL
    2000 740i sport
    Congrats!
    http://www.bimmerforums.com/forum/sh...112&styleid=50
    I know this is for a 750 e38 but Post 9 and 10 maybe?
    Sent from my SM-N960U using Tapatalk
  4. #104
    Dec 2011
    Lancaster CA
    ^Wow, that's quite a solution. I'll look into it. Probably will open up the electrical box on Bank 1 to check wiring and continuity.
  5. #105
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Check the voltage at the connector, I don't have the pinout handy (home tomorrow if nobody chimes in) +12 volts, ground, and a signal wire. Sounds like one wire is broken maybe.
    12 volts come from the fuses in the back of the DME box.
  6. #106
    Jan 2015
    Tempe, AZ
    1995 525i/5
    I've gotten a code similar to that when the timing wheel was so far off that it wasn't registering at all, just food for thought.
    1995 525i 5-speed - Thread
  7. #107
    Mar 2010
    I'm pretty sure the wheel-off code is different (something about position) than the electrical code. This is a situation where having true BMW codes vs Peepee codes can be very crucial to understanding what is really happening there.
    Kouks glad its back up and running well!
    Ay: That link about the magnetized bolt problem is CRAZY. Never heard of that but it makes some sense.
    2003 M3CicM6 TiAg
    Former:
  8. #108
    IL
    2000 740i sport
    Its so odd that anytime someone says they've replaced their cam sensors with new oem sensors and the issue is still on the one side it triggers me to thing about the magnetized bolt issue. This has been added to my troubleshooting muscle memory. Without evidence of it happening and working for someone else, you'd probably think I was nuts...
  9. #109
    JimLev's Avatar
    Sundance Mesa, NM
    Wiring at connector info.
    +12 volts comes from F1 in the back of DME box, goes to pin 1 on DME connector, red/blue wire inside the wire box.
    Pin 2 is the signal wire back to the DME, yellow wire inside wire box.
    Pin 3 is the ground, brown wire inside wire box.
    A magnetized bolt?? It's possible but not likely, the small bolt is far enough away from the tip of the sensor that it shouldn't effect it.
    The tip of the cam sensor is normally slightly magnetized, it has to be to function.
  10. #110
    JimLev's Avatar
    Sundance Mesa, NM
    OK, I'm going out on a limb here, thinking outside the box.
    Check the coil connectors and the ground wire on bank 1.
    Maybe start with cylinder 3 first.
  11. #111
    Quote Originally Posted by dannyzabolotny View Post
    Ours ran like a pig when that happened though, his seems to run OK
    PRICE CUT on ALL FABRICS
  12. #112
    Dec 2011
    Lancaster CA
    I’m on a trip now so I’ll have to catch up with all your suggestions after turkey day gents. I did think of the timing wheel at first, but I’m certain I torqued it correctly and it was in the correct position, and the fact that it runs smooth tells me it’s not that. The P0343 code is a high code, meaning an open circuit, and with multiple CPS installed and still getting the same code the problem is in wiring at the plug or beyond. There was one time where I was getting frustrated and the CPS plug on Bank 1 was not letting go so I may have damaged something internal to the Bank 1 elec box, so that’s my first plan of action.
  13. #113
    Dec 2011
    Lancaster CA
    Checked both CPS plugs, both red/blue leads were 12 volt, both yellow leads were 12 volt, and both grounds had continuity, so there is no open circuit at the plugs. Also opened up bank 1 e box and no damage to wires. Still p0343
    Changed CPS bolt to one from a spare fan clutch, still p0343
    Checked ground wires at the plugs in bank 1, still p0343
    Noticed MAF wire was not routed through clip on intake to stay away from engine, so clipped that just in case it was affecting the magnetic CPS, but still p0343
    Since there is no open circuit on either side at the plugs, and multiple CPSs were used on bank 1 and now bank 2, I’m beginning to think this is a secondary code caused by something else.
  14. #114
    Mar 2010
    No oil or coolant on the DME connector?
    While coolant-on-connector is an old and well known problem, I've now seen a number of "oil pooled connector" DME's, and heard of 2-3 more, and I suspect that theres a new long-term failure mode that is emerging with age here... At first I assumed that it was the oil level sensor but for a couple reasons I think thats far less likely than the oil pressure switch which has oil at pressure, and, very little vertical to overcome, and, fewer breaks in the harness sheathing making for a better ability to force oil upstream to the connector.
    Like the coolant problem, that causes semi-random errors because the contamination can affect any of the nearby pins. The connector that is concerned there is the middle 'sensor input' connector. While the coolant thing is most likely to rot out its own thermostat & temp sensor related pins first, the oil contam seems less specific... so... could take out a cam sensor signal easily I suspect.
    If its oil, and hasn't been happening so long that the inside of the DME is contam'd, then contact-cleaning the connector and pins should result in a short-term fix that works pretty well for a limited period, at least proving the diagnosis...
    2003 M3CicM6 TiAg
    Former:
  15. #115
    IL
    2000 740i sport
    Could this be an alignment of the upper timing cover being off causing incorrect camshaft reading at the sensor?
    https://www.newtis.info/tisv2/a/en/e...covers/AnfTlNf
    Did you follow this installation procedure that says:
    Note:
    The timing case cover is pressed down onto level of cylinder head by cylinder head cover
  16. #116
    Mar 2010
    Yeah, I've heard shops say that they thought that the UTC being slightly misaligned causes these problems.
    I'm a bit skeptical unless the cover is really way off... I mean sure its worth quick checking, but I wouldn't be super optimistic about that one unless it really visibly isn't flat w/ the head.
    2003 M3CicM6 TiAg
    Former:
  17. #117
    IL
    2000 740i sport
    Only reason i mention it, is because the covers have been off a bunch of times and this is a newer error code I believe?
  18. #118
    Mar 2010
    The other thing A is that if you have a proper scanner the electrical codes are distinctly different than the position codes. I suspect a lot of people end up chasing their tail one way or the other because of that! Either chasing electrical when it’s position or chasing position when it’s electrical.
    2003 M3CicM6 TiAg
    Former:
  19. #119
    JimLev's Avatar
    Sundance Mesa, NM
    Did you check what I wrote in post 110?
  20. #120
    Dec 2011
    Lancaster CA
    Here's what I did today
    1. Measured Ohm resistance on both old and new CPS between terminals 2 and 3. Old ones were both at 0 ohms, so I tried between any other terminals and still 0 Ohm. Then I measured the new CPS and resistance between terminal 2 and 3 was 1160 and 1120, as they should be. Installed the new CPS. Started and drove it for about 5 minutes, including in Sport mode and mashing down on the pedal. No codes. Shut it down in the driveway, restarted, and then the P0343 came back. Not sure why the old CPS show 0 ohm, if both were failed then the engine would not have run as good as it did for months. Currently the engine runs fine, you can feel a slight wobble at idle and during the initial part of any harder acceleration. At cruise it runs very smooth.
    2. When the CPS were removed I shot photos inside the CPS holes to get the position of the timing wheels. Using GAS and Besian photos of the timing wheels and front covers, I did some geometry and then used the solution on photos of the timing wheel. Comparing my shots of the CPS holes, with the engine turned over at several positions, and the geometry solution on a timing wheel, its evident both timing wheels are in the appropriate place and are not loose or out of position. The shots were not accurate enough to measure exact timing angle, but based on the photos of the timing wheel installed on the VANOS and the geometry, they appeared to be in the correct locations.
    3. Purple: the cover appears to be in proper position, and yes, I'm getting really good at removing and replacing them.
    4. Jim: Checked all coil connectors and ground both banks.
    Still looking for a solution, and I need to get INPA to talk to the DME.
  21. #121
    IL
    2000 740i sport
    INPA not working?
  22. #122
    Dec 2011
    Lancaster CA
    ^Will not talk to DME. Talks to other modules just fine. Maybe the DME is the problem. I feel like I’m chasing my tail on this DIY. Why would electronics do this when they were running perfectly fine before. I opened up the e-box and it was evident no one had been in there, maybe since manufacture.
    The only thing I moved electronically was the coil e boxes on top of the engine. Continuity for the CPS were good.
  23. #123
    IL
    2000 740i sport
    Does it connect to your DINAN 7 DME fine?
  24. #124
    Jan 2016
    Ca
    2001 525it
    Leverage is a great thing, along with penetrating oil
  25. #125
    JimLev's Avatar
    Sundance Mesa, NM
    Your plugged into the OBD port under the dash.
    The connector gets 12 volts at pin 16 from F25.
    The data is sent over pin 7 directly to the DME. This should be the only data wire from the OBD connector to the DME.
    The other two pins, 4 & 5 go to ground.
    Very strange you can connect to other modules but not talk directly to the DME.
    Maybe try letting the car go to sleep, disconnect the battery for 10-15 min. Turn key to POS 2 for a few sec then back to off. Reconnect battery and see what's what.
    Purplecty suggestion would also be a good thing to try.
  1. Rough idle..P0011 code
    By ake11 in forum 1995 - 2001 (E38)
    Last Post: 06-13-2014, 08:11 AM
  2. P0011 code at 80k on 2001 740iL - need advice
    By krosnovski in forum 1995 - 2001 (E38)
    Last Post: 12-03-2012, 06:19 PM
  3. Dreaded P0011 Code...Help Please!
    By 2000bmwe38 in forum 1995 - 2001 (E38)
    Last Post: 05-12-2012, 04:38 AM
  4. 02 325xi P0011 code--help needed PLEASE!!
    By kmayer20 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-27-2009, 03:45 AM
  5. Replies: 0
    Last Post: 12-08-2008, 02:00 PM
