Page 2 of 2 FirstFirst 12
Results 26 to 50 of 50
Thread: 90 535i voltage regulator/ alternator question - solved
  1. #26
    Dec 2004
    CT, USA
    e28, e34, e39
    Visual inspections although necessary aren't really sufficient. You need to be doing voltage drop tests on the wiring to see where your problem is.
    demet
  2. #27
    Sep 2001
    Sharon CT
    Im still working on the car but here are the update... I checked the chassis ground for the battery, no corrosion and it is firmly in place.
    Next I turned the car on,
    tested b+ at alternator - 12 to 13v at idle,
    tested the starter where the alternator and battery wire are on 1 post - 12 to 13v,
    tested the battery cable where you would jump start the car under the hood - 12 to 13v..
    I changed out the 80amp fusible link that is not riveted in since i have 2 new ones.. tested at 10v.
    So now im going to dig around and look for the 50amp fusible link and test that, Im hoping that is the cause, because if not then im stumped.
    The OBC test is vacillating between 10.4 and 11.3v.
    Herr, wirf Hirn vom Himmel! ... oder Steine, Hauptsache er trifft.
    88 Alpineweiss / black E30 M3 -Project.
    Brilliantrot / black US SPEC 3/90 prod e34 M30b35 535i 5spd - Modded.
    98.5 Tiag Silber /black e36 m3 - Modded.
    99.5 Estoril Blau /dove e36 m3 - Modded.
    07 Crimsonrot /black E83 X3 6spd - Stock..
  3. #28
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    Looks like a BIG voltage drop between your fusible links and your jump start terminal. Corroded wiring in between both I bet. Overlay a new set of wires, doesn't have to be very thick or follow the existing wire through the carpet and the firewall feed it out an open window onto the engine bay, and retest for voltage at the fusible link. You should have your answer.
    Shogun, are both fusible links 80A ?
  4. #29
    Sep 2001
    Sharon CT
    From what ive read the first fusible link is 80amp, 2nd one that heat shrunk wrapped is 50amp.
  5. #30
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    Looks like a BIG voltage drop between your fusible links and your jump start terminal. Corroded wiring in between both I bet. Overlay a new set of wires, doesn't have to be very thick or follow the existing wire through the carpet and the firewall, feed it out an open window onto the engine bay, and retest for voltage at the fusible link. You should have your answer.
  6. #31
    Sep 2001
    Sharon CT
    Attach53984_20181021_112425 (1).jpg This is the only real corrosion im able to find at this time.
    I've also disconnected anything that was added on just now and the readings went up slightly. I have an electric fan that is temp sensor controlled that was attatched to the terminal block in the pic. The car is still only showing 12v at idle. Before anyone asks there is Nothing else that is added on. I haven't had a sub/amp attatched in quite some time. I do apologize for not mentioning that earlier.
  7. #32
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by alang1990 View Post
    This exercise will demonstrate what? That the new wire doesn't have a voltage drop.
    jeez, Roberto, give it up already
  8. #33
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    Quote Originally Posted by ross1 View Post
    Yes, and conversely, that the old wire does. I thought that was obvious, Roberto.
  9. #34
    Dec 2004
    CT, USA
    e28, e34, e39
    Quote Originally Posted by Neel View Post
    That thing is nasty. I think it can be taken apart and cleaned or the bolts and nuts replaced.
    demet
  10. #35
    Dec 2004
    CT, USA
    e28, e34, e39
    And where are you located? Update your profile with your location.
    demet
  11. #36
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    Yes that is nasty especially on closeup. Remove and try sanding the nuts and terminals and whatever else you can get to there with sandpaper. This will work if its not as bad as it looks. Try that before overlaying wires.
  12. #37
    Sep 2001
    Sharon CT
    Replaced hardware with stainless steel hardware the plate in the block is still a little rusty but i scraped it the best i could.. instant results, car is up and going and at 13v at idle. Why I immediately did not do that was a couple of techs that looked at it said while its not helpful, it shouldn't cause that much of a voltage drop. Well, it seems to have solved my issues for the time being, Im still going to replace the 50amp fusible link, but this is a step in the right direction.
  13. #38
    NW suburban Chicago
    hiss by my window
    Glad it's fixed without any gymnastics.
    That terminal block is usually squeaky clean, even on the rust belt cars I am cursed with. I wonder if your car has been "wet". Anyway, a bit of acidic wheel cleaner ought to spiff up the terminal block. A bit of spray grease or battery terminal protectant after is probably a good idea too.
  14. #39
    Dec 2004
    CT, USA
    e28, e34, e39
    Yeah right. Good thing you came here for a second opinion. Or was that a third opinion?
    demet
  15. #40
    Sep 2001
    Sharon CT
    Came here for a 2nd opinion. While those guys may be awesome at acura's.. Im going to not ask regarding my car anymore. However, its still only charging at 13.xx at idle, or while running. So the hunt goes on but I am alot more comfortable with the car now that it is above 11v. I even replaced all of the fuses about a week ago just as a precaution. Looks like I will be ordering a new block where the battery and starter wires go. Going to try and pickup an 50amp fuse block tomorrow.
  16. #41
    Dec 2004
    CT, USA
    e28, e34, e39
    If it's high 13's at idle then you're fine. If it's low 13's then you need to do more work. What brand voltage regulator did you use? Hella is a good brand that produces good voltages. And it's cheap too.
    demet
  17. #42
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    That is fine in 13s, case solved, I added solved in the thread title. Corrosion, deposits and oxidized contacts is one of the biggest problems on our old cars. On occasion, the damage may be so extensive that the device cannot be salvaged because the oxidation has penetrated plating or other surfaces to corrode much more deeply. Otherwise, you can use various brushes or cleaners, or both, to clean and restore oxidized contacts.
    BMW even has a TI: Stabilant 22A Electrical Contact Enhancer Model: All BMW
    Complaint: Connectors which carry low current are more likely to form deposits which affect the resistance of the circuit through the plug connector. Depending upon the particular circuit these deposits can cause malfunctions and consequently activate warning lamps and check control indicators.
    Remedy: Part replacement can temporarily stop the problem.
    If the connector is the problem then without disconnecting the connector measure the resistance of the circuit running through the connector to make sure the connector has a high resistance. A good resistor will have close to 0 ohms resistance. Visually examine the male and female terminals in the connector housing by removing them. Look at the integrity of the wire crimps, and in some male terminals the integrity of the weld of the male pin to the terminal. Then reinstall. With a zero residue electrical contact cleaner liberally spray the male and female connectors, and allow the air to dry. Apply Stabilant 22A to both male and female terminals so they are saturated, and reconnect the connectors while they are still wet. When the Stabilant 22A dries it will leave a thin coating of polymer film which is conductive between mating surfaces, and is non-conductive between adjacent pins. It can also prevent the formation of more harmful deposits.
  18. #43
    Sep 2001
    Sharon CT
    Quote Originally Posted by demetk View Post
    I purchased the one you linked, the hella one. Its low 13's - 13.5 at idle, and stays consistent even when I'm driving. I should be able to replace the 50a link tomorrow, if i can find the block at an audio store... Here I thought the car was just getting pissed at me because I bought another e36 m3 lmao. I'm still going out to the car and turning it on in disbelief that it was just something that was so simple and over looked. I could have saved so much time and frustration, oh well. The car now has all new fuses, new fusible link, new ignition coil, new starter, tested good working alternator, new belts sans AC belt because its winter and i said the hell with it. I have developed a mystery oil leak but im okay with it, it means i have to step up the time-table on rebuilding the motor i have torn apart in the basement, and try to find some funding for ITB's and a tune, megasquirt is the low end of what i want to go with.
  19. #44
    Dec 2004
    CT, USA
    e28, e34, e39
    Never let a car know you are interested in another.
    demet
  20. #45
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    If the terminal block not the alternator, and if the alternator is doing :
    I purchased the one you linked, the hella one. Its low 13's - 13.5 at idle, and stays consistent even when I'm driving..
    ..then how was this possible earlier before the terminal block repair :
    tested b+ at alternator - 12 to 13v at idl.
  21. #46
    Sep 2001
    Sharon CT
    So the chassis ground for the battery which is by the back seat, there was no corrosion there at all.
  22. #47
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    No I meant how come the direct alternator check showed 12-13v before the repair, and now, after fixing the terminal block, it shows only 13-13.5v ?
  23. #48
    Sep 2001
    Sharon CT
    Initially the alt read 13.7 to 13.5 (on page 1).. on this page i wrote it would go from 12 to 13... after reading your last comment i felt it would be foolish if i did not not at least go test the B+ on the alt one more time even though it is now working correctly (the obc is showing 13.5 to 13.7, and I am good with that). I just did a test across all points of testing and it is consistent at mid 13s. So it really does seem everything is working as it should.
    Thank you and everyone else for their help.
  24. #49
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    Wrong reported observations greatly complicate swift and correct diagnosis, usually. Fortunately it was not the case here for you.
  25. #50
    NW suburban Chicago
    hiss by my window
    Almost as much as your jibberish
  1. New Voltage Regulator - Alternator Overcharging
    By 5Toes in forum 1988 - 1996 (E34)
    Last Post: 04-29-2018, 12:23 AM
  2. 90 535i - Automatic - Transmission fluid questions
    By travbjork in forum 1988 - 1996 (E34)
    Last Post: 07-20-2011, 10:31 PM
  3. Regulator / Alternator Questions
    By ryankokesh in forum 1999 - 2006 (E46)
    Last Post: 12-08-2010, 12:56 PM
  4. voltage regulator/ alternator help Please
    By TheJonas in forum 1975 - 1983 (E21)
    Last Post: 11-08-2009, 08:13 PM
  5. technical question regarding alternator and voltage regulator
    By Blazin95Red325i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-27-2005, 10:31 PM
