I used to be a forum member for 10 years but cannot recover my old profile or so I thought until I hit "Enter". So you can see my old car, I will have to upgrade pictures.
Anyway, I just bought a 2015 M235i with the more expensive Harmon Kardon factory system. In my previous car (Accord) I ran the usual 6 1/2" mid-bass in the doors with a cross-over linked 1" sail panel tweeter. In the rear deck-lid I had a pair of two-way 6 1/2" speakers. And finally, in the trunk I had a conservative 10" 4 ohm Dual-voice coil sub. All of my speakers were Alpine's "high-end" edition "R" Series.
I noticed that BMW unfortunately makes use of nothing larger than a 4" driver, except for the two comical 8" drivers under the seats. I was looking to put my single 10' sub back in the trunk. As for the fronts I read where BMW uses a Fiber Optic cable to carry the signal to the amp. So I don't know if you can even bypass the factory amp. As I have a nice four-channel Audio Control amp, that would easily take care of the door speakers and the ones up in the rear deck lid. Also I have a mono 1200 watt rated Kicker amp for the single 10" driver.
Any advice for the audio rookie?
Thanks,
David
97' Artic Silver m52 Vortech V3 11PSI, RWHP 353.98, AA Custom Tune, RMS Aftercooling, VAC 1mm Over-Sized Valves, Stage 2 VAC head, Supertech Springs Ti Retainers, Schrick 264/256 Cams, M50 Manifold, Turner "Shorty" headers, Magna Flow racing cats, Lucas 42lb'rs, Walboro 255, Bosch 803 MAF, IPT Stall Converter, IPT Performance M3 ZF5HP18, 5-Speed Auto, 3:91 gears, Spal, Fluidyne, Dinan, Anza, Bilstein, H&R, PFC, HKG, Brembo, Auto Meter, VDO, Plasma Euro Gauges, ZKW, Prolumen, Viper 5901, Beyern, Yokohama, Monarch A1 Hand Controls, OG member of the "NO FEET" Hands Only!" drivers club.
