Results 1 to 3 of 3
Thread: how to install power steering hose
    Oct 2018
    san diego ca
    bmw 545i 2004
    Hi: I want to know how can install power steering hose for bmw 545i 2004 E60
    1.- How can I install the power steering hose?
    2.- Where is conncecting the three sides of the power steering hose?
    3.- And can you bring me a diagram for the instructions for install the power steering hose
    Sounds like you may be in over your head if you need detail instructions to change a hose. Not trying to be rude, or discourage you, but it's as simple as disconnecting each end and removing the hose. Then filling and bleeding the system with the proper fluid. However, there may be lots of other things in your way that may have to be moved or removed.
    Mar 2011
    OK
    e30, e61
    This page is a good start for you: https://www.newtis.info/tisv2/a/en/e...mp-oil-supply/
    Based on the image you shared, this is likely the specific hose: https://www.newtis.info/tisv2/a/en/e...supply/PTCkaV8
    That said, if you're having a hard time figuring this out with the digital version of the service manual available (what I've linked), you probably should consider seeking professional assistance.
  1. Replies: 9
    Last Post: 09-16-2011, 03:54 AM
  2. Installing new Power Steering Hoses
    By arktissilber in forum 1991 - 1999 (E36)
    Last Post: 02-18-2010, 05:51 PM
  3. Changing power steering hose (Pump to Steering Rack) install guidance
    By Solidhead in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-03-2005, 03:55 PM
  4. Power steering hose question...
    By EvanL in forum 1992 - 1999 M3 (E36)
    Last Post: 07-29-2002, 01:30 AM
  5. can someone help me with removing power steering hose clamps?
    By pikachu in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-29-2002, 01:32 PM
