Results 1 to 12 of 12
Thread: EDC and SLS delete
    Oct 2018
    Conway SC
    2001 bmw 740il
    EDC and SLS delete
    Hello friends. I'm totally new to the forum, so just bear with me. I have a 2001 bmw 740il with the EDC and SLS rear suspension. It has hydraulic lines going to the struts and a electric plug on the top stem of the struts. I want to get away from this system. I have purchased 2 rear stock strut assembly's from a 98 model with no EDC or SLS and no wires coming from the top stem of the struts. Could I get away with leaving the pigtail undone on top of the struts and just bypassing the hydraulic lines like I have saw you guys do? I am a 21 year current mechanic so I should understand anything you throw at me hopefully. Just would like to get it right the first time I start on it. Thanks again in advance for your help!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    You are in the wrong forum, ask in the E38 forum, not E32. I will move it to the E38 forum, there are the experts for that model.
    Oct 2018
    Conway SC
    2001 bmw 740il
    Thanks shogun! I appreciate your help. I'm sure I will catch on soon. U guys are great and I love all your post. Keep up the great work!!!
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    There is an old thread from Edwin about deleting sls. I’ll see if I can find it. - from bimmerboard - but good.
    http://www.bimmerboard.com/forums/posts/806044/
    Jul 2016
    San Diego
    1998 E38 750iL
    Quote Originally Posted by Dillysdaddy View Post
    Yes. Leaving the electrics unplugged is totally fine. To bypass the hydraulic lines, I recommend using the method where you get a pre-cut and flared brake line from NAPA, and use it to create a loop under the driver's seat area. This way you are using proper fittings which will prevent any leaks down the road. Check here for info: https://www.bimmerforums.com/forum/s...7#post28684727
    Oct 2018
    Conway SC
    2001 bmw 740il
    Ok guys yall are awesome with your help. Just a couple more questions if possible. If I leave the wires unplugged on top of my rear struts on my 01 bmw 740il, that won't throw any stupid lights on right? Believe it or not, mine has absolutely no lights going crazy on the dash, and I would really love to keep it that way if possible! Also the used strut assemblys I got from the rear of a 98 740il, have no wires or the hydraulic lines going to them like I previously stated. Do u think my car would now sit about properly in the rear as the front sits in ride height? If you guys think I'm good, then I'm going to get started on it asap. Just wanted a second opinion before getting started. As always I appreciate your help and patience with my newbie self!
    Nov 2016
    NY
    Many have done this - no, you should not get any error lights. So, this set of rear struts - does it have springs? Your best bet is to get the front struts too - it will be balanced better - the rates will match.
    Oct 2018
    Conway SC
    2001 bmw 740il
    It is complete with springs. I was just hoping they would match somewhat and the car would sit halfway normal. Currently it sits down in the rear as I have a leaking shock and the leveling accumulators are bad as well.
    Nov 2016
    NY
    Currently - that is on the old sls / edc setup? Once you swap, they will not be influencing ride height
    Oct 2018
    Conway SC
    2001 bmw 740il
    Yes. It is down in the rear with the old EDC/SLS setup. That's gonna suck if it's still down in the rear after I install the non -edc/sls setup. That will be a real bummer.
    Feb 2013
    The Motor City
    1997 750 IL
    It will sit just like a 740 once you get the 740 non edc sls mounts, shocks and springs for the rear. My 750 is like this.
    ---- Processing Individual ----
    Z1XX Upholstery
    Seats front and back in Epingle / leather englishgruen,
    As Schl.Nr. B9EG.
    Front seat backrest in Montana Englishgruen (No. 8 174 861)
    Other interior equipment as for Volleder Nappa englischgruen,
    Schl.Nr. P5EG
    Oct 2018
    Conway SC
    2001 bmw 740il
    Thanks pal. I really appreciate all you guys help. Hopefully I can get started on it soon.
  1. EDC./ SLS delete replace with Bilstein Pro kit
    By Turlock in forum 1995 - 2001 (E38)
    Last Post: 08-06-2017, 01:38 PM
  2. Replies: 27
    Last Post: 02-06-2016, 02:43 PM
  3. Power Steering Pump Mod-SLS Delete
    By M5W in forum 1988 - 1996 (E34)
    Last Post: 03-31-2009, 07:26 PM
  4. Power Steering SLS Delete
    Last Post: 03-31-2009, 09:45 AM
  5. SLS deletion thread
    By Tj Hunter in forum 1988 - 1996 (E34)
    Last Post: 09-24-2007, 10:32 PM
