Hi. I'm new to this forum. 2 weeks ago i bought a BMW 328i xDrive 2009 year. The car had halogen lights. My first upgrade were the HID lights. I put them on and they were working for 10 seconds, then they started flickering and shutting off. After some researches i went to autozone and picked up a relay. I connected the relay to the battery and after couple hours of work i fixed the HIDs and they are working perfectly. I turned off the car but the lights still stay ON. Even if i lock the car it has electricity on the lights. And it is funny because only the passenger light stays on,i took out the relay and HID bulb and still the same, even with the halogen bulb ( before i did not had that problem)
Can someone had this type of problem? Or can someone reccomend what should i do, check.
Thank you
try swapping the bulbs to see if the issue follows the bulb or stays on that same side. it could be a bad bulb?
