Results 1 to 25 of 25
Thread: 2003 325i e46 turbo project
    Sep 2018
    texas
    03 325i
    Got a turbo I am putting in my e46. Turbo is in intercooler is in and all the piping. Now the problem I am running into is on the original intake right behind the maf there is two parts that tee off pretty sure one is the vent not sure what the other one is. I know they can't g under pressure so what can I do about them?
    Mar 2016
    Australia
    e30 318i, 135i
    Are you talking about the F connector? One goes to the fuel pressure regulator, and you do want boost going to that.
    The other goes to jet pump for brake booster, you dont want boost going to this so use a check valve.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    There are people who have figure it out or are figuring it out, as well as shops. Here is a shop that has done them:
    http://www.enjoytechnica.com/product...-turbo-tuning/
    Sep 2018
    texas
    03 325i
    pretty sure it is idle control valve its right above the throttle body
    Jul 2005
    PEI, Canada
    2001 330i
    Tough to offer any advice without a picture...and I know this engine pretty well.
    Sep 2018
    texas
    03 325i
    ill get some pics. any ideas were to get a wire diagram for my piggyback ecu
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by codylee91 View Post
    Please dont
    Mar 2003
    Hell Hole, NC
    325i
    Please dont
    ^^^ This man speaks the truth. 🙂
    Jul 2005
    California
    Bima
    what piggyback do you have?
    just curious that is so oldschool like rrfpr status.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Please dont
    See what I mean, Cody? You're getting the same advice here that I gave you on the mechanical forum.....if you're going to blow in it, you need to do it the right way.
    You've got a "kit" that wasn't intended for your car, a piggyback crap computer that doesn't even have wiring diagrams or instructions, you don't know what to do about the CCV system, and, I'd be willing to bet you don't have a dyno or an experienced tuner. With that combination of missing information, parts, and experience, you're going to melt the motor.
    Chris Powell
    BMWCCA 274412
    Jul 2005
    PEI, Canada
    2001 330i
    Perhaps he's found someone with more experience than you and I to answer his questions? :P
    Nov 2008
    Newburyport, MA
    '02 325i
    Quote Originally Posted by ba114 View Post
    Why would you want boost going to the fuel pressure regulator? how does the e46 regulator react to that? I'd figure your better off giving the regulator vacuum reference from the intake side of the turbo.
    Jul 2005
    California
    Bima
    you want the fpr to see the boost because it will add fuel pressure to boost 1:1.
    it reacts very well like a fpr should.
    Sep 2018
    texas
    03 325i
    sorry been gone been in the field. I have a dyno and experienced tuner that I bring all my cars to here in fort hood. I have a aem piggyback which I have the diagram for didn't have it for the bmw dme. and I not using some cheap ebay turbo kit. I cant find a kit for this car so I'm using a turbonetics turbo I have made the manifold. well I lied the intercooler kit is from ebay.
    Aug 2011
    philadelphia PA
    1993 325is
    Piggy back is not a good time on these cars. With dual vanos and e-throttle its a nightmare.
    Just keep the factory harness and MS43. Its plenty good for most reasonable power goals and you can retain all the bmw functionality. Its slightly more challenging to tune than a aftermarket ecu, but its worth it as you wont be playing with 2 computers trying to get them to play nice together
    Plus I find the OEM knock detection and vanos control to be extremely accurate.
    Nov 2008
    Newburyport, MA
    '02 325i
    Quote Originally Posted by Robocop View Post
    Im surprised the OEM fpr would know what to do with positive boost pressure
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by Mrk1 View Post
    It doesn't know how to do anything. Its a brainless mechanical device with a spring and a diaphragm.
    Nov 2008
    Newburyport, MA
    '02 325i
    Right and I'd think the OEM FPR is setting up to increase full pressure with the stronger vacuum associated with higher load from a NA engine. Now to have positive pressure indicate higher load, I'm surprised it has the same result. If it works then it works I guess.
    Jul 2005
    California
    Bima
    ur only surprised because u don't know what a fpr is for :P
    plus u thought it was some sort of computer or something.
    Jul 2005
    PEI, Canada
    2001 330i
    80% of my posts on here are through a VSAT.
    Aug 2011
    philadelphia PA
    1993 325is
    Im not sure m54 FPR references vac/boost in stock form. Yes that seems dumb but its true.
    The vac line on the fpr lands before the throttlebody in stock form. No vac there. I have heard it is just there to contain fuel in the event of a possible diaphragm failure.
    Now when it sees boost will it climb 1:1? Possibly.... Ive been tuning a USA MS42 powered M52TU with similar fuel setup and the fuel table doesn't show any signs of fuel pressure fighting boost pressure.
    You would think the fuel table would have a strange shape if fuel pressure is not holding a constant differential over manifold pressure.
    Sep 2018
    texas
    03 325i
    ok... so I shouldn't run a piggyback also I have a ms45 not ms43 don't no if that matters or not and I should run boost to the valve above the throttle body?
    Aug 2011
    philadelphia PA
    1993 325is
    You are going to want to swap to MS43. MS45 is more complicated to tune and there is not much support for it.
    Yes its okay to run boost to the IACV. You will want to go over it to boost proof it. Real hose clamps, epoxy the plastic fittings, etc.
    Jan 2017
    RI
    1994 325is
    E36 FPRs run on manifold vacuum which should be weaker at load/ open throttle. Therefore, it handles boost well. Not sure for e46, if it references vacuum ahead of TB it is stronger at load as you say.
    Sent from my SM-G960U using Tapatalk
    Sep 2018
    texas
    03 325i
    ok thank you...Anything else?
  1. 2003 325i e46 turbo project
    By codylee91 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-19-2018, 05:19 AM
  2. E46 Turbo Project Progress
    By jdholder in forum Track Car Builds
    Last Post: 11-16-2011, 06:56 PM
  3. Upgrade my 2003 325i e46 exshaust system
    By los13 in forum 1999 - 2006 (E46)
    Last Post: 12-03-2009, 02:44 PM
  4. Club Racing E46 Turbo Project
    By Neil in forum Forced Induction
    Last Post: 03-07-2007, 10:38 AM
  5. 2002 325i(E46) turbo system
    By overkill in forum Forced Induction
    Last Post: 09-28-2003, 09:52 PM
