Results 1 to 16 of 16
Thread: Where does this hose go
    Oct 2018
    Clementon nj
    1999 328i
    1999 328I sedan E46
    Manual trans
    2.8l
    Tring to figure out where this lil guy goes,diagrams helpful
    Sent from my SM-G965U using Tapatalk
    Jan 2017
    USA
    E21, E46
    Looks like a vacuum line off of your secondary air pump.
    Oct 2018
    Clementon nj
    1999 328i
    Quote Originally Posted by RobertDenali View Post
    Where should it attach to
    Jan 2017
    USA
    E21, E46
    More than likely the secondary air pump valve which allows air to flow from the secondary pump to your catalytic converters however blocks air flow from returning in the opposite direction.
    So the line looks to be a vacuum line for that purpose.
    I will go look at my zhp to see where it exactly connects.
    Jan 2017
    USA
    E21, E46
    My 2004 has a different setup. I will go check the Bentley manual for you.
    Jun 2012
    New Mexico
    2003 328i
    That hose goes to a check valve which goes to the solenoid for the secondary air valve. The vacuum supply is tapped off of the intake manifold runner.
    Jan 2017
    USA
    E21, E46
    Oct 2018
    Clementon nj
    1999 328i
    So I pulled the intake manifold to do some looking
    Seems like someone previously removed the I take manifold to replace the starter
    Sadly they lost most of the bolts,misrouted wires,pinched and broke vacuum lines
    So I'll be putting it back together for now
    I've ordered new CCV hoses and oil seperator
    I'm glad I pulled the manifold to locate the solenoid for the secondary air pump,because I would have never known about the nonsense the last guy left behind
    Any diagrams showing correct routing of wiring and hoses????
    Jan 2017
    USA
    E21, E46
    Since you pulled the intake manifold I would highly recommend replacing all of the vacuum lines in the areas you cannot reach when it is attached.
    Oct 2018
    Clementon nj
    1999 328i
    I plan on it,the main reason I pulled it was to access the vacuum lines
    Bmw really didn't leave much room lol
    Jan 2017
    USA
    E21, E46
    No they didn't! There are orange gaskets on the intake manifold. Replace those as well.
    Jan 2017
    USA
    E21, E46
    Oct 2018
    Clementon nj
    1999 328i
    Part number 7
    Goes from here to where?
    Last guy filled the stub in picture with silicone lol
    Part of the cvv??
    Apr 2015
    USA
    1998 BMW 328is
    Part number 7 connects to part number 3 (the photo you circled). It’s part of th ccv system. I recommend replacing they are made of plastic.
    Oct 2003
    Seattle
    99 M3
    Secondary air pump vacuumed actuation valve
    http://www.realoem.com/bmw/enUS/show...diagId=11_2203
    Jan 2017
    USA
    E21, E46
    If it was me I would also replace the CCV system since you are there already.
    You can buy a ccv kit from ecstuning fcpeuro etc.
  1. where does this hose go?
    By benemorius in forum 1991 - 1999 (E36)
    Last Post: 05-16-2007, 10:23 PM
  2. Where does this hose go?
    By cyclingches in forum 1983 - 1991 (E30)
    Last Post: 02-23-2007, 12:17 AM
  3. Where does this hose lead into?
    By sexy325 in forum 1991 - 1999 (E36)
    Last Post: 05-07-2006, 02:57 AM
  4. ***where Does This Hose Go???
    By str8chillin718 in forum 1991 - 1999 (E36)
    Last Post: 10-19-2005, 04:32 PM
  5. Where does this hose go????
    By krlemke in forum 1983 - 1991 (E30)
    Last Post: 10-12-2003, 11:41 AM
