Results 1 to 5 of 5
Thread: What’s this sound - fuel pump? ‘01 325Ci
    Oct 2007
    Bolton, MA
    2001 740iL, 2001 325Ci
    Hi all. I noticed a sound coming from what seems the passenger rear wheel; kind of a buzz/whine. Doesn’t seem to be coming from engine. Fuel pump? Is this normal or is the pump on its way out?
    https://youtu.be/90wJdScB9Hg
    Thank you,
    Jay
    '01 325Ci Convertible, 5-speed
    '01 740iL, Stahlblau with beige interior & 18" M-Pars, GROM bluetooth
    '03 X5 3.0 six cyl, Gray on gray
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Definitely fuel pump noise. When was the fuel filter replaced last? Has the pump ever been replaced?
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Oct 2007
    Bolton, MA
    Don’t know on either - just bought the car 3 or 4 months ago. Maybe do fuel filter and see if it changes? And if not, plan on the pump going soon? Runs fine at the moment - but the moment the pump goes, I bet she no run so good.
    Are these fuel systems pressurized?
    Thank you
    Mar 2015
    west chicago il
    Remove the back seat bottom and access cover on the right side and check the pump. The original ones have a mfg date and a one time crimp type clamp on the hose. If it is original or a cheap aftermarket China part, I would change it. New vdo (oem) pump is about $150. Same part that bmw dealer sells for a fraction of the price. You can try replacing the fuel filter first but risk getting stuck somewhere if the pump quits. Fuel pressure should be about 50 psi.
    Oct 2007
    Bolton, MA
    Quote Originally Posted by randy72877 View Post
  1. Low Voltage to Fuel Pump 01 525i Wagon
    By savannahjbo in forum E39 Touring / Wagon
    Last Post: 10-27-2017, 12:31 PM
  2. Fuel Pump Fuse 325ci
    By javalos71 in forum 1999 - 2006 (E46)
    Last Post: 11-18-2010, 05:43 PM
  3. buzzing sound from fuel pump
    By guyasin325is in forum 1991 - 1999 (E36)
    Last Post: 11-06-2006, 09:07 PM
  4. Does this sound like a fuel pump?
    By scaringkidz in forum 1988 - 1996 (E34)
    Last Post: 10-06-2006, 10:31 AM
  5. continious loud fuel pump sound.
    By rajiz325i2001 in forum 1999 - 2006 (E46)
    Last Post: 05-22-2002, 01:45 PM
