Results 1 to 19 of 19
Thread: Just bought a 1999 328i now what?
    Oct 2018
    Clementon nj
    1999 328i
    So I picked up a silver 1999 328i for $1200
    Manual trans
    166k on the dash
    It's in ok shape but needs some love
    Known problems:
    -hood latch cables need to be replaced
    -existing clutch fan is noisey,I plan on swapping to electric fan
    -ac compressor makes a sound similar to a valve tap while driving with it engaged
    Only a mild tap while at idle
    -something is vibrating possibly exhaust related,I'll be looking at that
    -when I bought it the housing for the cabin air filter was in the trunk,hardware gone
    -seems like the shifter isnt as smooth as it could be,maybe bushings or time for new gearbox oil
    -the usual plethora of dash lights,waiting for scan tool in mail to determine what abs sensor,brake pad sensor needs to be replaced
    And to look into srs light
    -headlights are foggy AFFFFF
    -need to replace various interior parts,pelican parts
    I completely rebuilt a 1995 325i years ago but it was an auto and had vermin lol
    So any pointers,suggestions
    I'd like to wake the car up a bit,tighten up the overall performance
    What's my best bang for my buck,Ebay exhaust componants are fine by me,bought this car as a beater,but always loved the style of these cars
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I assume it is an E36, not E46, will move it to the E36 forum.
    Please update your profile with the model
    My Cars:1999 328i
    Mar 2011
    PNW
    LS E46
    Quote Originally Posted by shogun View Post
    Wow you really don't know that the E46 sedan debuted in 99? He has an E46.
    Jan 2005
    Japan
    it is not 100% clear, some E36 were even built year 2000, see ETK and see the 3 series forum index: 1991 - 1999 (E36) ,1999 - 2006 (E46)
    For example E36
    328i Coupe was built till 04/1999
    328i convertible till 09/1999
    328i Touring till 05/1999
    he just mentions " picked up a silver 1999 328i "
    The Netherlands
    DE-spec E36 328i/M3 cab
    Quote Originally Posted by Liquidity View Post
    1998 even, at least here in EU.
    IG:
    Jan 2018
    Earth
    Quote Originally Posted by Seancy85 View Post
    Sounds like an E36 to me.
    Oct 2018
    Clementon nj
    1999 328i
    The 1995 325i is definately an e36
    And I'm not actually sure about this 99 I just picked up
    Pretty sure the headlights mean e46 right???? e46????
    Sent from my SM-G965U using Tapatalk
    Jan 2018
    Earth
    Yes, that's an E46.
    Oct 2018
    Clementon nj
    1999 328i
    Quote Originally Posted by Bostongruen View Post
    About 8 years ago I restored a 1995 325i,auto for a friend who had fallen on hard times
    The car sat for years and got infested with mice needless to say alot of damaged wiring in need of repair
    I went over the whole car and repaired anything that was damaged
    Yesterday I bought a 1999 328i(pretty sure it's a e46)
    But seems like alot of you bmw fanatics disagree?
    Maybe I'm wrong
    And I dont think anyone offered up any actual advice
    Like hey you should replace the exhaust the stock system is very restrictive
    Or hey check out this short throw shifter kit
    Etc,etc
    Here's some pics you tell me?
    Oct 2018
    Clementon nj
    1999 328i
    Nope e46,and it says 1999 328i on my profile
    Apr 2014
    UK
    1995 BMW 328
    If the grills fall out when you slam the bonnet it's an E46, if the hole for the grills isn't in the bonnet it's an E36
    Advice? Hmm, replace grills
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Jan 2018
    Earth
    Etc,etc
    Hey, check out these google image results for 1999 BMW E46 sedan. You should have no doubt that the car that you own is an E46.
    Hey, check out this E46 forum. You'll get a lot more support than you will here in the E36 forum.
    All good natured sarcasm aside, good luck with your project.
    Oct 2012
    Detroit, MI
    E36, E70, i3
    Guys he did post in the E46 subforum. Shogun moved it.
    Mods please move back to E46 subforum so he can the proper guidance. Or delete and have him start fresh.
    Good luck OP
    Oct 2018
    Clementon nj
    1999 328i
    Quote Originally Posted by Nanniepoo View Post
    Good luck OP
    Thank you
    Lol
    The Netherlands
    For example E36
    E36 Compact even as far as 2000.
    IG:
    Jan 2005
    Japan
    clarified, will move it to E46 Forum
    Pls add model to your profile
    My Cars: 1999 328i
    Jun 2012
    New Mexico
    2003 328i
    The stock exhaust is very good. Best possible outcome messing with that is to spend time and money on it for no gain, more likely you'll spend money and time on it and it will sound like garbage and lose power.
    Realistically you can pick up some power with an M54 intake manifold, either the B25 or the B30 is an improvement. I think the M54B30 is the best choice. This job is moderately difficult and there are a few items to do while you're in there. You would need the crank vent valve and hoses, upper and lower intake boots and intake gaskets. I would also recommend replacing the water pipes on the side of the block. You will have to adapt your throttle body to the manifold as it doesn't bolt on and the DISA valve is different as well, so you want to make sure your manifold comes with one. The intake manifold tuning on the M52TU is a compromise, that's the only place they really left power on the table.
    In stock form it makes good power. Aftermarket intakes are useless, don't bother. If you do swap the manifold you want to look for a tune to make the most of it but even on stock software it'll run better.
    SanDiego,Dallas,Miami,Orl
    Too Many
    My 99 M3 is an e36... Parts store ppl get this confused for some reason so i usually say 98 M3. The e46s are nice but personally i prefer the e36s for simplicity and theyre generally easier to repair (ive also had 7 e36s in the past 20years, so im biased). The e46 is 1000lbs heavier than the e36s and not that much higher in hp. For the extra 1000lb, i d go e39. They have beefier suspension and brake components that can allow you to beat on it. I drifted my 528i every day for years before it got a 1jz and the only thing i broke were coilovers from slamming curbs
    That being said, my favorite place for parts is:
    www.rockauto.com
    www.carid.com
    www.ebay.com
    www.craigslist.org
    www.offerup.com
    Sent from my SM-G930P using Tapatalk
    Current lineup: 99 BMW M3vert (project) , 05 Mazda RX-8, 04 Mercedes CLK320, 03 Chevy Express 1500 (work van).
    Previous rides: 07 Mazda RX-8, 92 BMW 325iNV, 94 BMW 325iC, 94 BMW 325i S50 M3 clone, 84 Mitsubishi Cordia Turbo, 84 Mazda B2000 lowrider, 88 Toyota Tercel, 88 Honda Accord, 93 BMW 318i, 95 Nissan Altima, 89 Toyota Camry, 95 Mitsubishi Eclipse GS-T, 93 BMW 318is, 84 Toyota Tercel, 96 Mitsubishi Eclipse GS-T, 97 BMW 528i 1JZ swap, 94 Acura Integra 4dr, 88 Toyota Corolla Wagon, 97 VW Jetta GLS, 86 Toyota Corolla AE86 4A-GZE supercharged engine swap, 94 Lexus LS400, 95 Isuzu NPR Turbo, 01 Suzuki TL1000R, 98 Honda CBR600F3, 99 Yamaha R6 and countless other dirt bikes and toys
    May 2013
    Sydney, Australia
    1998 328i Convertible
    WD40 for foggy headlights. Works a treat
    Sent from my HTC 2PS5200 using Tapatalk
    "You must learn from the mistakes of others. You can't possibly live long enough to make them all yourself."
  1. Just Bought a 1999 323i and had it serviced for $1000, did i get ripped ???
    By BMWSlice in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-26-2009, 01:27 PM
  2. just bought a 2000 328i. have a few questions.
    By slick007 in forum 1999 - 2006 (E46)
    Last Post: 01-13-2006, 08:08 PM
  3. Newbie here, just bought a 97 328is
    By Smitchell08 in forum 1991 - 1999 (E36)
    Last Post: 09-11-2005, 10:24 PM
  4. just bought a 96 328i!
    By 96 328ic in forum 1991 - 1999 (E36)
    Last Post: 11-12-2004, 05:38 PM
  5. Just bought a 2000 328i 5spd loaded sport pkg.
    By tendi23 in forum 1999 - 2006 (E46)
    Last Post: 08-21-2004, 09:16 PM
