Results 1 to 14 of 14
Thread: Fuel pressure high at idle, low in boost
    Oct 2005
    Nördlich des Äquators
    M3TTst2Meth-K1300S-1100G
    I show 67 psi fuel pressure at idle and 62-63 psi at 14 psi of boost, AFRs are lean at 12.6+ right now
    E36 M3 TT st 2 with aeromotive 340 fuel pump and stock FPR
    before throwing a new FPR at this , just wondering if this could be caused by something else?
    Oct 2012
    washington, dc
    96 E36 Vert 03 E39 M5
    Quote Originally Posted by Haifisch M3 View Post
    Hose going to the fuel pressure regulator ok ?
    http://www.bmwmregistry.com/detail.php?id=13792
    * E39 M5 SterlingGray -RIP 11/2018
    * E36 328 vert Schwarz - ~TurboProject underway
    * E90 335i Sedan MonocoBlau - Daily ToddlerTaxi
    Oct 2005
    Quote Originally Posted by Turbohugh View Post
    haven't really gotten under there yet
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Vacuum line is an obvious first step, but that fuel pressure reading, if correct, is sky high. I've pulled 5 FPR from junk yard cars and tested them with wildly different results (ranging from 2.5bar to 4.35bar)... so it is possible your FPR is bad.
    That said... I could never get the stock 3/2 valve setup to work properly with a high flow fuel pump. It over powers it. When you go to replace the FPR, make sure you use a new Pierburg only. Do not bother with a Bosch unit, they come out of spec (two brand new ones read 4.0bar on my bench tester). Don't be surprised if fuel pressure is still an issue, even with new parts.
    Oct 2005
    Quote Originally Posted by Braymond141 View Post
    looks like I am over 4.5 bar with mine
    Never heard of the Pierburg one, do you have any experience with aeromotive 13109 FPR?
    Apr 2006
    Minnesota eh?
    86 325es
    Sounds to me like your pump is just overrunning the regulator at idle, which is when nearly all the fuel needs to go through the regulator. The pressure in boost is about right.
    Upstate
    E28
    This. I always encounter this problem with Walbro 450 and stock fpr.
    Oct 2005
    so this is nothing to be concerned about, does not affect fuel-supply in boost?
    Apr 2006
    Minnesota eh?
    86 325es
    It’s going to make idle and part throttle difficult to tune. Should get an aftermarket regulator and then get a tune revision.
    Oct 2005
    Mar 2016
    Australia
    e30 318i, 135i
    A 340 wont overpower the stock regulator. Not from my experience anyway....450 is a different matter.
    Nov 2013
    VA
    E36
    Quote Originally Posted by ba114 View Post
    I'm running the 340lph from rally road. It definitely overpowers the stock 3/2 valve causing idle issues and rich conditions in boost. Went to the aeromotive 13109 and haven't had any problems since. I also had a lean condition at some point and it was the vacuum line going to the fpr. Make sure it is still in tact.
    From previous builds I've seen, it looks the stock 3/2 valve can only keep up with the 255 pump. Anything higher than that should really have an adjustable fpr to be safe.
    Jan 2006
    Oakhurst, CA
    I wouldn't say it overpowers the FPR (I've never tested a standalone FPR before), but 340lph+ most definitely overpower the 3/2 valve setup. If I recall correctly, even a 255lph pump can cause issues.
    Vancouver, B.C., Canada
    '97 M3
    You can disconnect the 3/2 valve from the fuel system when you install an aftermarket FPR, just leave the electrical connector connected to the 3/2 valve.
  1. Replies: 59
    Last Post: 03-06-2016, 12:40 AM
  2. Replies: 2
    Last Post: 05-08-2015, 06:10 AM
  3. Low Fuel Pump pressure + High Idle + Lambda 1222 = ???
    By surge82x in forum 1988 - 1996 (E34)
    Last Post: 08-23-2010, 02:51 PM
  4. Fuel Pressure specs? Rough idle+misfire (already checked the usual suspects)
    By Iceblade in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-03-2008, 08:45 PM
  5. Fuel Pressure Regulator...Rough Idle?
    By StillinSaigon in forum 1983 - 1991 (E30)
    Last Post: 02-27-2006, 07:34 PM
