Hello I have a problem in my 2008 650i convertible high beam, low beam working just fine in both side but when I want to flash or turn high beam on then the right side will not work but driver side working normally, the local garage said the bulbs are fine but the problem is a small engine inside the headlight is responsible to turn high beam on need to be replaced.
Any idea about what he is talking about ??????
Although the headlights are Bi-Xenon (the dipped-beam cut-off lifts when main-beams are required) they also have a separate main-beam bulb. As the garage is a bit confused about the headlight operation it will be well worth your time checking and replacing the main-beam bulb as described here:
https://www.meeknet.co.uk/E64/BMW_E6...ulb_Change.htm
My BMW Repair YouTube Channel
