RM European Auto Parts
Results 1 to 7 of 7
Thread: Which TIS has DSC and Brake light warning light circuit?
    Aug 2018
    Kernersville, NC 27284
    2003 Z4 E-85
    Can someone point me to the TIS for a 2003 2.5? I've had it in the shop several times, but the mechanic says the lights have to be on to diagnose the circuit. Since these lights come on for any reason or no reason, I cannot reproduce this at the shop. I'm thinking there is a loose-fitting connector somewhere that is either heat sensitive or bump sensitive.
    Dec 2013
    Chicagoland area
    EXOTICS
    I'm assuming this will answer your question:https://www.newtis.info/tisv2/a/en/e...c-mk60/mKPccez
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Are you visiting a BMW specialist? If the lights are getting illuminated, the computer will have codes, even after the lights go out.
    Chris Powell
    BMWCCA 274412
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Try www.bimrs.org to find a reputable indie shop in your area.
    Jan 2016
    Ca
    2001 525it
    Lights don't come on for no reason and yes somebody will have to dx. Because the those two warning lights came on their is for the most likely only one problem, not multiple ones. Meaning if the fault is in dsc and since dsc feeds its signal to other modules they will also be affected, that's way you get the two lights. Or for that matter if the brake light switch was bad it could probably make dsc come on.
    Jun 2002
    E39M5, E500 4WD
    I'm actually wondering what warning lights you'd get, on an early Z4, if the brake fluid level is low? That could explain the intermittent.....
    Chris Powell
    BMWCCA 274412
    Aug 2018
    2003 Z4 E-85
    When I had the brakes redone, the brake reservoir was brim full. Haven't seen any signs of leakage so it must be the dsc that is flaky.
    Will the BMW testing computer pick up where the fault is?
  1. [2003 E85] Help! DSC + BRAKE + TPS warning lights permanently on
    By ckkcz4 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-11-2013, 05:22 PM
  2. DSC, BRAKE, ABS warning lights stay on
    By adapteruser in forum 1996 - 2003 (E39)
    Last Post: 07-15-2009, 03:50 PM
  3. ABS, DSC, brake light warning lights fixed
    By E30wheelman in forum 1996 - 2003 (E39)
    Last Post: 06-25-2008, 04:52 PM
  4. Brake wear warning light
    By knudsonm in forum 1991 - 1999 (E36)
    Last Post: 04-04-2003, 01:22 PM
  5. brake pad warning light??
    By jefiddler in forum 1991 - 1999 (E36)
    Last Post: 11-13-2002, 04:26 PM
