Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 3 of 3
Thread: Humming, and vibration that increases with speed
    Oct 2018
    Houston, Texas
    '03 325CI
    Angry Humming, and vibration that increases with speed
    I have a '03 325CI, with 103,280 miles. Humming comes on, not sure form where, just know that it gets louder the faster i go. Once I reach around 35 to 40 miles per hour it begins and it seems that the car starts to vibrate as well.
    The rear wheel bearing where replaced about 2 years ago, so not sure what this might be. Could it be the differential oil? Help not sure want to go to a dealer as they are expensive.
    Any and all help will be greatly appreciated.
    Dec 2013
    Chicagoland area
    EXOTICS
    Probably best to perform an inspection of the suspension/drivetrain/chassis while vehicle is on a lift,
    would make it much easier to diagnose problem correctly.
    Possibility of this being a safety issue, perform ASAP!
    Oct 2018
    Fishers, Indiana, USA
    1999 BMW M3
    It could be any number of things.... I've had vibration issues tied to speed that were related to alignment, wheel issues, brake issues, etc. The last issue I had was due to uneven tread wear on directional tires that couldn't be rotated. No amount of balancing could fix it, so tires had to be replaced with ridiculously low miles.
  1. Shaking 740IL while increasing & decreasing speed
    By C5VettesVipers in forum 1995 - 2001 (E38)
    Last Post: 07-13-2011, 09:00 PM
  2. Vibration increases as speed increases
    By 74BMW2002 in forum 1991 - 1999 (E36)
    Last Post: 11-08-2009, 01:20 PM
  3. Violent Vibration at Constant Road Speed
    By ryan_george in forum 1983 - 1991 (E30)
    Last Post: 04-29-2007, 06:57 PM
  4. Humming sound/vibration from right front tire
    By colin318i in forum 1983 - 1991 (E30)
    Last Post: 02-04-2007, 04:46 PM
