Results 1 to 2 of 2
Thread: e30 m50 Restoration - Turbocharge or Supercharge?
    Feb 2015
    Vienna, Austria
    1990 BMW e30
    Lightbulb e30 m50 Restoration - Turbocharge or Supercharge?
    Hello guys,
    I have never written anything before here, only read and researched and collected info and you have no idea how helpful you were. So first of all a big thanks to all of you that unknowingly helped me with the restoration of my project.
    So here is a thank you pic:
    The car: e30 1990 316i 2 door.
    The engine: 1990 m50b25 NV out of an e34 with around 70 000 km on the clock.
    The transmission: 5 speed manual ZF.
    The Diff: 3.25 LSD 25%
    Suspension: Bilstein lowered 10 mm front and back (no coilovers since no track days, only weekend car). New thicker sway bar, new poly bushings, front and rear strut bars.
    Steering: e46 330i purple tag steering rack with power steering, e46 inner and e36 outer tie rods, 3 turns lock to lock.
    Brakes:
    290 mm front discs, 4 piston calipers from Wilwood (not sure if you can call it a BBK :P). Stock 250 mm rear brake discs (converted from rear drums and was quite a pain to be honest). Changed all brake lines and complete rear trailing arms and bushings. Brake cylinder from an e32.
    Exhaust
    : Schmiedmann exhaust headers/manifold. Custom made straight piped 3'', cat delete (I know I was going to FI it later so I made a 3'' exhaust from the start).
    Intake: Stock m50 manifold, stock throttle body, K&N air filter kit, new 3'' MAF (although I keep having some minor idling problems :/).
    Cooling: New stock radiator, new water pump, new thermostat, new cooling hoses. Stock clutch fan, never had overheating issues after the changes.
    A/C Delete.
    NEW PAINT, NEW INTERIOR.
    Here are some more pics of the car.
    Old vs new exhaust headers:
    A front view:
    A rear view:
    After the paint:
    Next steps:
    1) New "classic" steering wheel.
    2) Supercharge the engine.
    The reason I think supercharging is in my case a better option than turbocharging is because the car is driven on the street only, during weekends. It spins the wheels sometimes when I am shifting into 3rd with 100 km/h. I do not want that turbo kick when I am on the highway and downshift, I would rather have the linear power of a supercharger.
    My goal is to get around 400 bhp mark. Will that be doable with:
    1) New camshafts.
    2) Rotrex C38 / 81 (with intercooler and oil cooler).
    3) Thicker head gasket to lower compression to around 9.xx:1. (I would really love some suggestions here).
    4) Bigger (500 cc) injectors, new fuel pump (255 l/hr), new tune for 100 Octane fuel.
    5) Subframe reinforcements for the added torque (from Garagistic. They really have some nice stuff).
    6) Stock m50 manifold and throttle body.
    I would love to hear some suggestions from everyone who has had experience with that. I would love to make that process as pain free as possible. :P
    More pics following soon.
    Feb 2015
    Vienna, Austria
    1990 BMW e30
  1. E30/M50 Supercharged build- Did I miss anything?
    By RoccoB517 in forum Forced Induction
    Last Post: 04-10-2014, 07:52 AM
  2. E30 E30 M50 Swap Car In Michigan!!
    By Isolatos in forum 3 series & Z Series
    Last Post: 07-26-2010, 03:02 PM
  3. E30 E30 M50 Swap Car In Michigan!!
    Last Post: 07-20-2010, 03:27 PM
  4. E30 E34 m50 oil pan/pickup/dipstick tube for E30 m50 swap
    By kenndoggy in forum Engines, Performance Parts & Software
    Last Post: 03-30-2010, 03:08 PM
  5. Eaton M62 supercharger on e30/m50
    By L.A.Snow in forum Forced Induction
    Last Post: 01-18-2007, 03:22 PM
