Results 1 to 17 of 17
Thread: Wired turn signal issue
    Sep 2017
    Northeast
    2001 M Roadster
    So I took my M Roadster out for a spin this weekend and no issues with the turn signals. Took it out tonight and right blinker blinks fast. I have seen this before on my other cars and bikes. When bulb is out, or wrong resistance bulb is in, or a relay. Well, it dawn on me that over weekend I did not drive in the dark. So I shut the lights off, blinker goes to normal speed. I turn my parking lights on, it blinks 3x faster. All bulbs are working. I shut the parking lights off and it’s back to normal. This just started happening because I drove this car in the dark before and so not recall blinkers going bonkers. Any ideas?
    SF Bay Area, CA
    BMWs: 1; MINIs: 1
    Bad ground on one of the turn signals, probably in the rear housing.
    I like the unicorns.
    '99 Z3 Coupe - Jet Black/Black (1-of-114)
    '99 M Coupe - Estoril Blue/Black (1-of-82)
    '03 540iT - Sterling Gray/Black (1-of-24)
    '16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Quote Originally Posted by DimrBimmer View Post
    So I shit the lights off
    Did it hurt?
    Nathan in Denver
    Dec 2017
    Plainfield Indiana
    1999 M Roadster
    Best post I've seen in a while!! Too funny
    Sep 2017
    Northeast
    2001 M Roadster
    Quote Originally Posted by s8ilver View Post
    Did it hurt?
    LOL. In my defense, it was roughly 1:30am and I was typing it from my phone and “u” and “i” are right next to each other. That said, it is pretty funny indeed. Now instead of laughing, propose a solution. One that does not involve a jar of lube, or a trip to proctologist.
    Aug 2015
    Denver, CO
    Is the 3x blink on both sides or just one? If one, have you swapped bulbs side to side to see if the problem followed?
    Nathan in Denver
    Sep 2017
    Northeast
    2001 M Roadster
    One side only. Will be doing that over weekend. Still curious why is it not doing it all the time and only does it when parking lights are on. I guess I will know more on Saturday.
    SF Bay Area, CA
    BMWs: 1; MINIs: 1
    When the parking lights are off, your turn signal is able to ground through the parking light wire. But when the parking lights are on and there is voltage there, that ground path goes away.
    Either that or you are low on blinker fluid.
    Sep 2017
    Northeast
    2001 M Roadster
    Quote Originally Posted by JoshS View Post
    Oh wow, maybe I should go and pick some up ASAP, before it blows a rod...
    PS, thanks for clarification. Some of us just getting into this hobby. But hey, sense of humor is a healthy thing. So, bring it on!
    Aug 2015
    Denver, CO
    I remember the first time someone on my Audi forum told a guy to check his mirror fluid. The guy thought he was was being messed with and threw a fit until he realized there actually was mirror fluid.
    Nathan in Denver
    Sep 2017
    Northeast
    2001 M Roadster
    Funny, as I started reading your last reply, I was thinking it’s going to go the other way and was about to say “but there is fluid in the rear view mirror...” LOL
    Yes, and on one of my motorcycle forums, newbies always get dinged on getting the slower red model vs. faster blue due to wind resistance to the color shade and etc... some would bite.
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    If you let all the magic smoke out of your electronics they quit working.
    SF Bay Area, CA
    BMWs: 1; MINIs: 1
    Quote Originally Posted by z3forlife View Post
    Yeah. This is one place the British got it right over the Germans. They sell replacement smoke.
    Sep 2017
    Northeast
    2001 M Roadster
    So I let all the magic smoke out, kicked the hamster wheel and wiggled the connector on my front right blinker and it’s back to normal. Disaster avoided. Thank you to very wise members of this board. Wise or wise asses , nevertheless all is good. Thank you!
    Aug 2012
    Kansas
    Cool. Glad to hear you tracked it down. I'd pull the bulb and clean up the contacts and check the wire/connector. Use a little dielectric grease on reassembly and you should be good. These kind of problems have a tendency to come & go.
    Sep 2017
    Northeast
    2001 M Roadster
    Thanks for the tip!
    Batavia, IL
    00 M Coupe, 08 335xi
    Had the same issue recently. Swapped the relay and no change, took both the bulbs out to check for corrosion etc and put them back. Been working fine ever since
  1. Turn Signal Issue
    By acbru7 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-08-2006, 11:02 PM
  2. weird turn signal issue
    By Sam 330ci in forum 1991 - 1999 (E36)
    Last Post: 09-15-2006, 09:31 PM
  3. Parking light/turn signal issue
    By Jim Sykes in forum 1999 - 2006 (E46)
    Last Post: 02-19-2006, 08:02 PM
  4. Turn signal issue
    By arkaplan in forum 1999 - 2006 (E46)
    Last Post: 09-05-2005, 10:02 PM
  5. Right Turn Signal Issue
    By bvarianlvr in forum 1988 - 1996 (E34)
    Last Post: 08-17-2005, 02:12 AM
