Results 1 to 3 of 3
Thread: 740i 6spd driveshaft
    Jun 2017
    Denver, CO
    325xi; 740i
    Greetings,
    I am nearing the end of my 6spd and engine swap and only waiting on a clutch line from the master cylinder. This brings me to my question of driveshaft length from what I found between having the two transmissions next to each other (sitting here wondering why I didn't measure the total length of both transmissions and subtract) it looked like I need to lengthen the driveshaft by 6 inches which now that I think about likely isn't right since I didn't account for the guibo on the manual tran. (Moving it over since its brand new) What is the consensus from the few 740i manual swaps out there? I am looking forward to finally having my E32 back again, it already has a list of things to fix now too lol.
    With the driveshaft it looks like the PO thought ahead and had the u joint replaced with one that had a zerk fitting on it so lucky me.
    New Daily:
    2011 Audi A6 Avant 3.0T prestige. 1 of 368
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    94' BMW 740i 308k miles
    Fresh 72k mile engine with all new seals. True E34 Manual Trans Engine Harness. 6spd Transmission Swap, Getrag 420G. RHD LW Single Mass Flywheel. E39 M5 Clutch. E39 M5 Shifter. Factory Car Phone. Factory 6CD Changer. Factory Electric Sunshade. Not So Factory Factory Electric/Heated Rear Seats. E38 Heater Valves. E43 M5 calipers/brakes
    Sold:
    1996 Oldsmobile Aurora; 194k miles but with a bad paint job and dented fender resulting in a payout to buy the 740i
    Jun 2017
    Denver, CO
    325xi; 740i
    Oh forgot to add, the E32 is very good at hiding things both engine mounts and the transmission mount were bad and I never felt any kind of vibration from the car even running it hard. Which explains why my fan shroud broke and how I lost a fan blade despite no issues with the fan clutch.
    Further recommendation, if you plant to remove the engine from your E32 I highly recommend either dropping the sub frame with the engine or removing the entire front end. I didn't do either and the engine mutilated my condenser up front and bent the AC service port. Not fun.
    New Daily:
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    Sold:
    warwick RI
    E30/E32/F25
    When I had my drive shaft done they had me measure from the out put flange of the trans to the center support holes in the body. I used Carolina drive shaft they were awesome cheap and it took about 10 days
    Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
    G/F’s E34 92/ 525iT + F48 18/ X1
  1. E30 e39 6spd driveshaft
    By brittaine34 in forum BMW Parts Wanted
    Last Post: 03-23-2013, 01:39 AM
  2. 540i 6spd driveshaft
    By mhax in forum E34 Classifieds (closing soon)
    Last Post: 12-09-2012, 11:14 AM
  3. 740i 6spd VF S/C kit on the way
    By BlackWolf in forum Forced Induction
    Last Post: 07-10-2006, 10:21 PM
  4. EVO 6spd Tranny and Driveshaft....like WOAH!
    By M3joky8 in forum BMW Parts Wanted
    Last Post: 04-09-2005, 01:51 AM
  5. Replies: 16
    Last Post: 09-15-2001, 06:05 PM
