Results 1 to 9 of 9
Thread: New 2002 Owner, member, virgin
    Oct 2018
    Dallas, TX
    I just bought a 1976 2002. I saw it on a flat bed being towed to a junk yard. Basically, I chased the guy for 40 miles. It started. Paid $1000. Tomorrow I’ll clean it, get tires, change the oil, and fill it with gas. I’m going to make an attempt at a daily driver. Any suggestions for a newbie, what to look out for? Change plugs, plug wires, spray carb cleaner? Any help is welcome. It had or has rats but has been garage kept for years. Thanks.
    Jan 2005
    Denver, Colorado
    '76 2002,'16 435Xgc
    Welcome to the 02 madness...
    Join bmw2002faq.com, and read all the Tech Articles there. And use the Search there to locate any specific tech info you're looking for -- pretty much everything ever has been covered before.
    And make sure your brakes work well before you go driving!
    Oct 2018
    Dallas, TX
    Thanks, I appreciate the response. I did add break fluid today, inflated tires, tried to charge the battery. Tomorrow’s another day. When I say it runs, I mean I sprayed either into the carb and it ran enough for me to buy it. I need to fill the tank and see if it will stay running after I get a new battery. I tried jumping it after I charged the battery but it wouldn’t turn over. The lights all worked but the blinkers wouldn’t turn on either. I got the trash cleaned out and the windows washed. The upholstery isn’t terrible but the inside padding is shot. Wish me luck
    Oct 2018
    Dallas, TX
    Put a battery in it, changed the oil, added some gas, sprayed some ether in the carb. It fired up but the fuel pump began to leak immediately.
    Mar 2013
    Santa Rosa, CA
    1983 320i shell
    Looks just like what I owned back in 1980-86, only aged and neglected. Thank you for saving it.
    New York
    1974 2002, 2009 128i
    Every bit of rubber in that car is suspect. Do yourself a favor and change all the suspension bushings (poly is a lot easier to install than rubber, with some tradeoff in compliance and NVH), fuel lines, and soft brake lines before you try to start driving it; do the fuel pump too, since it's leaking. Gut the interior (it's easier than you think), pressure wash the carpet, inspect carefully for rust. Change all the fluids (trans and diff oils - Redline synthetics are the usual recommendation). Then a basic tune-up and see where you are.
    Life's tough. It's tougher when you're stupid.
    -John Wayne
    Sep 2012
    CT
    first thing I'd do is wipe down the steering wheel with clorox disinfectant wipes. Based on the number of tissue boxes on the dash, it looks like the last owner had a severe cold!
    Nov 2008
    SF Bay, CA
    72 + 75 2002's
    Pretty cool color, I would wash the paint well and wax it just to preserve what's there too.
    Current_SeeDee 1972 e10 Luna 1975 e10
    Past___Veronica
    1994 e36 Le-Ah 1987 e30
    Jan 2019
    Atlanta
    2002 E46 325 xit
    That’s a great start to an 02 adventure. Second the recommendation on the FAQ website. But don’t leave us hanging here.
    If you joined the FAQ forum, what’s your handle? I’d like to keep up with this...
  1. Help needed for new 635 owner / member
    By tkohl in forum 1976 - 1989 (E24)
    Last Post: 07-25-2009, 01:51 AM
  2. Replies: 10
    Last Post: 05-03-2007, 04:31 PM
  3. New 2002 owner with questions
    By 1976verona2002 in forum 2002
    Last Post: 02-19-2007, 09:50 PM
  4. New 2002 Owner (First Car)
    By CrimsonKarter27 in forum 2002
    Last Post: 01-01-2006, 04:14 PM
  5. New 2002 Owner...
    By wonder371 in forum 2002
    Last Post: 04-01-2005, 09:32 PM
