Results 1 to 7 of 7
Thread: Siezed engine due to unknown oil leak
    Aug 2018
    Atlanta, GA
    1997 Bmw 328i convertabl
    A couple months ago I had an oil leak I didn't know about. I drove the from home to school which is about 2 miles but a 25 minute drive and then back at the end of the day when i got back home i noticed the leak and checked and I was fully out of oil, nothing on the dip stick. I put more oil in then tried and find the leak, started the car and the engine seized, I have been too busy to fix anything until now and I put a concoction of half mystery oil and half transmission oil down the spark plug holes directly into the cylinders, will try and crank tomorrow does anyone know if my engine is still salvageable, if so any tips to get it running again, I am not very that mechanically inclined and have only done basic maintenance on the car
    Thanks, Aeden -1997 bmw 328i convertable
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E36 forum
    Jun 2010
    NY
    1997 328i
    Maybe you have a hole in the oil pan. Earlier e36's had an issue with the oil filter housing, there are oil ports in the back of it that can leak very fast, but yours shouldn't be an issue. How many quarts of oil did the engine take?
    Apr 2014
    UK
    1995 BMW 328
    If the oil warning light works and did not come on it should not be seized due to lack of oil, end of
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Sonoma Whine Country
    E12, E12, E36, E39
    If the oil light works, came on and you drove it no further than the side of the road you are probably ok.
    If the oil light works, came on and you continued to drive it, you're probably looking at an engine.
    If the oil light doesn't work, you might get lucky, but I wouldn't hold my breath.
    98 328is
    02 525ita
    80 528i
    81 528ia
    and decades of owning and driving BMWs
    Wichita Falls, Texas
    1997 BMW Z3 2.8
    Let us know what you find out...good luck.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    I'd make sure that your engine is/isn't seized and it's not a some other issue... based on your knowledge (nothing personal here).
  1. Unknown Oil Leak.. Headgasket?
    By cmybimmer in forum 1996 - 2003 (E39)
    Last Post: 01-03-2021, 04:39 PM
  2. Replies: 11
    Last Post: 02-02-2008, 02:06 AM
  3. Oil leak? Smoke from rear of engine...
    By TedK in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-22-2007, 09:58 PM
  4. Engine Gurus, Help me ... Oil leak.
    By avusblue in forum 1992 - 1999 M3 (E36)
    Last Post: 05-16-2003, 01:00 AM
  5. Oil Leak in the Front of the engine
    By scottycs in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-26-2003, 02:50 PM
