Results 1 to 23 of 23
Thread: E36 M3 COMPLETE T4 turbo kit with Technique Tuning Stage II OBD1 software
    Apr 2002
    Providence, RI
    95 m3
    SOLD E36 M3 COMPLETE T4 turbo kit with Technique Tuning Stage II OBD1 software
    Stage II turbo kit + UUC Cerametallic Clutch + 3" Full exhaust
    Price: SOLD
    I'm selling the turbo setup that came off my 95 OBD1 E36 M3 when I sold it in 2014. The core of the setup is similar to Technique Tuning Stage II kits, but with an upgraded turbo, larger intake tubing, and the huge intercooler. In addition, the other components you'll need to buy anyway are included: full 3" SS exhaust and UUC Ultrasmooth Cerametallic clutch. I typically ran at 8psi, but up to 13psi with 93 octane. I put approximately 8k miles on the kit. Unfortunately, I don't have a dyno sheet. I was doing some back-and-forth tuning from NickG of Technique Tuning before work necessitated my move across the country and selling the car. The software is probably the best part of this kit, being MAF-based and retaining the stock OBD1 ECU. It's truly suitable as a daily driver.
    Condition:
    There is no shaft wobble in the turbo. Parts are in great condition. Some dirt and scratches to be expected from 8k miles
    Included: (what's in the pictures)
    - T4/GT40 turbo (360 thrust bearings)
    - Cartech T4 turbo manifold (S50)
    - Cartech aluminum engine mount (for 3" piping to air filter)
    - Two options for intake: 4" to 3" reducer or 4" (good luck...it might fit)
    - 3" aluminum heat coated intake piping from intercooler to manifold
    - 2.5" piping from turbo to intercooler
    - 3" downtube with wastegate flange
    - Tial 38mm wastegate
    - 3" SS exhaust with Magnaflow muffler and 4" tip
    - V-band attached (removable) Magnaflow catalytic converter
    - UUC UltraSmooth Cerametallic clutch + (Sachs) pressure plate
    - SS Oil feed line for turbo
    - 45-degree bend fitting for oil return line
    - Large aluminum intercooler 3" inlet/outlet and mounting brackets
    - T-clamps everywhere and silicone couplings
    - Tial 50mm BOV
    - Technique Tuning 3" MAF (purchased the new style directly from NickG)
    - Technique Tuning software and chip encryption board
    - Lucas 42lb injectors
    - Catch can and hose
    - Silicone hose for BOV and wastegate
    - Heat shield mat for placing under intake manifold (see picture on my intake manifold)
    - Summit fuel pressure gauge with mount
    - 15psi boost gauge with matching amber lighting and T's for tapping into vacuum.
    - Complete assembly for 2 gauges mounted on A-pillar (note only boost gague is included)
    - A stock clutch if you want it
    Additional things you'll need (not included):
    - .140" MLS Head Gasket (I purchased mine from VAC motorsports)
    - Some bolts. I've included everything I could find, but intercooler mounts need 4 bolts, as do wastegate flanges.
    - Gaskets for wastegate flanges and T4 turbine
    - Hose for oil return line (fittings included except for oil pan fitting that needs to be welded)
    - Air filter (fits in bumper by fog light) and 3" flexible connector to turbo compressor
    History:
    I started with a kit purchased from EMC on this forum, which is where the manifold, most of the piping and the giant intercooler came from. From there, I upgraded the turbo (specs below) and a full 3" exhaust. I also purchsed these parts new: Cartech mount, UUC clutch, Tial BOV, Lucas 42lb injectors and Technique Tuning MAF. After the NickG tuning and fixing a broken knock sensor, some intake leaks, the car idled smoothly and felt insane at 13psi.
    I documented the turbo install here:
    Turbo install pictures: part 1 (long, 56k death)
    Turbo install part 2: MLS headgasket, ARP studs
    Turbo install part 3: Final steps
    I'll send the buyer all the pics (switched ISPs and lost the old hosting space).
    Turbo specs:
    The turbo itself is a T4/GT40, with the exact same compressor housing and wheel from the gt35r (technically a gt40wheel) with a p-trim .58 on-center turbine to fit the Cartech manifold. Its just a standard 360 thrust bearing.
    Shipping:
    Buyer pays all costs whether freight or FedEx. I'll come up with an estimate, but exact price will be determined on day of shipping.
    Pickup available in Providence, RI.
    Photos https://imgur.com/gallery/O8eItHP
    Feb 2016
    Rogers AR
    1995 BMW M3
    Pictures don't seem to be working
    Apr 2002
    Providence, RI
    95 m3
    Thanks. Just fixed it and they're all up now.
    1995 M3: Custom turbo Click here for writeup
    MLS headgasket, ARP studs, Vanos timing write up: Click here
    Apr 2002
    Providence, RI
    95 m3
    Price lowered to $4500 + shipping.
    Apr 2002
    Providence, RI
    95 m3
    FREE delivery if you're along my drive from Knoxville to New Haven, CT (DC, Baltimore, Philly, NYC). I'm driving on Monday and bringing this with me. If you're on the way, willing to meet me, then delivery is free. Let me know ASAP.
    NY
    skateboard
    Quote Originally Posted by caldweb View Post
    Interesting
    ― George Orwell
    Apr 2002
    Providence, RI
    95 m3
    Yep. Someone is going to save ~$200 on shipping, and not have to worry about damage during shipping. One more day. I'm driving on Tuesday now.
    Apr 2002
    Providence, RI
    95 m3
    Items are now in New Haven, CT. Price lowered to $4200
    NY
    skateboard
    Nice wish this was obd2
    ― George Orwell
    Chicago
    '99 M3
    I used to run this same setup. I LOVED how fast that turbo would spool with the oncenter housing and Cartech manifold.
    TEC-3R, T4 GT40, WISECO, EAGLE, SUPERTECH, O-RING'D "FRANKENSTEIN" STROKER.
    NY
    skateboard
    Quote Originally Posted by trthrrt489 View Post
    How is oil drainage with that manifold?
    Apr 2002
    Providence, RI
    95 m3
    It worked perfectly, but I was very careful with the angles of the drain and getting it welded to the pan. See this album for drain pics: https://photos.app.goo . gl/yXEmjiK5Hs54YrcH6 (remove spaces in the url)
    Apr 2002
    Providence, RI
    95 m3
    Bump. Price lowered to $3700
    Apr 2002
    Providence, RI
    95 m3
    Bump. PM me with any questions. I'm pretty sure pictures are working now. If not, please let me know.
    Apr 2002
    Providence, RI
    95 m3
    Hi, folks. Bump. I need to clear this kit out of my house. Please PM me with offers.
    Feb 2009
    Hackettstown, NJ
    1998 328i
    Willing to sell the intercooler setup?
    Mar 2019
    Los Angeles.
    98' M3 [Alpine/Black]
    Interested - shoot ya a PM
    Jan 2019
    houston
    2017 F150, 97 M3
    still available? Haven't gotten a PM response
    Apr 2002
    Providence, RI
    95 m3
    Bump again! The kit is still available. $2800 + shipping!!
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Looks like a decent low buck complete kit for someone who can use an OBD1 tune and is interested in power in the 400 rwhp range.
    Apr 2002
    Providence, RI
    95 m3
    $2600 shipped! PM me for more pictures. Full 3" exhaust included.
    Feb 2002
    Ny
    Hey I'm interested in the kit let's talk 646-423-5098. Marc
    Apr 2002
    Providence, RI
    95 m3
    Sold. Thanks everyone.
  1. Technique Tuning Stage II Turbo Kit : E36 M3 : Full 3in Exhuast
    By Alpine 318is in forum Forced & Chemical Induction Parts
    Last Post: 07-12-2016, 12:42 PM
  2. Technique Tuning Stage II Turbo Kit : E36 M3 : Full 3in Exhuast
    By Alpine 318is in forum Engines, Performance Parts & Software
    Last Post: 06-28-2016, 03:08 PM
  3. Technique Tuning Stage II Kit for E36 reliability
    By blaam3 in forum Forced Induction
    Last Post: 12-06-2012, 12:18 PM
  4. E36 E36 m3 complete fog light kit
    By DiegoMesa in forum BMW Parts Wanted
    Last Post: 05-11-2011, 12:14 AM
  5. FS: Complete Technique Tuning Stage II turbo kit w/extras
    By ADVANT123 in forum Race Cars & Track Parts
    Last Post: 05-09-2006, 02:23 PM
