Results 1 to 4 of 4
Thread: 2001 Z-3 loss of power
    Apr 2018
    amherst, ma
    2001 bmw z3
    When the outside temperature exceeds 90 degrees, my 2001 Z-3 (3.0) loses power. It still runs smoothly, but its loss of power feels like retarded spark. Any idea what might be causing this?
    Jul 2004
    Houston, TX
    36 Cylinders
    Any codes/ check engine light?
    Any modifications done to the engine?
    High air intake temperatures will cause some power loss due to air density changes, but not severe.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Apr 2018
    amherst, ma
    2001 bmw z3
    No engine modifications and no engine warning lights on, but the power loss is significant.
    Springfield, Ohio, USA
    1998 Z3 Roadster
    My experience with a sudden dramatic loss of power with no codes was a clogged catalytic converter. Sometimes everything was fine and sometimes it was clogged due to a broken piece of ceramic. It finally set a code for a downstream O2 sensor.
    It could also be a bad DISA valve or a bad VANOS or bad VANOS seals. Those rarely set codes either, yet have a noticeable impact on power.
  1. Air in fuel system, loss of power Bmw 320td Compact, 2001
    By mohitpuri29 in forum 1999 - 2006 (E46)
    Last Post: 10-07-2015, 05:56 PM
  2. E39 530i 2001-loss of power, noise in a cabin
    By rawmn in forum 1996 - 2003 (E39)
    Last Post: 06-21-2013, 01:34 AM
  3. 525D 2001 Shaking/Jerking loss of power
    By Justin Case in forum 1996 - 2003 (E39)
    Last Post: 03-23-2008, 06:13 PM
  4. Strange loss of power with Euro HFM/chip/injectors
    By Brett in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-29-2002, 06:15 PM
  5. stalling at stoplights, loss of power, what could it be?
    By ebm34 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-30-2002, 01:51 PM
