Hey guys, I am David from Germany and wanted to share my ongoing project with you, an e36 318i going M50b20tu Turbo.
I am trying to make a lot of pictures, so hopefully someone else can gain something from here .
Base:
- e36 318i
Mods:
- M50b20tu
- stock pistons
- 2x Head gasket with decomp plate
- Clutch & Flywheel - e*** ftw
- Holset HX35W
- Selfmade Topmount Manifold
- 440ccm injectors
- Ecumaster DET3
- RSR Performance widebandlambda KIT with LSU 4.9
- Compression Ratio around 8,5:1
The Plan is to run about 1,2-1,5 bar of boost in closed loop and hopefully more than 320hp .
The pictures show the car atm, some "toys", the engine ( thats what i did yesterday, nothing special just time consuming) and the draft of the new coolant circuit.
see ya later.
Edit: I will update the first post with the newest information, to keep things clean here..
Some Update on this:
The Manifold is ready soon, have to do the last welds. The Turbo will go through the hood.. ARP Head Studs with decomp + 2x Gasket. More updates coming
7.3:1 compression? why?
anything lower than 8.5:1 is useless.
The compression ratio was pretty much the result of combining the crankshaft, pistons and rods. But i havent told you that the engine is a stock m50b20tü with just the decompression plate now to keep it simply at first. My fault sorry.. big injectors, ecu etc are staying the same.
Cheers
I tested the same parts in my engine and it worked just fine. Its not useless, its not necessary*.
https://www.instagram.com/p/BqConDhg2CV/
When calculating with the formula for the otto cycle, it basically is as Raimo says. Its not necessary, but you dont loose much if you go down till 6:1..
8,5:1 seems to be a common value, but i dont get why this seems like some kind of religion... especially on boosted cars you gain much headroom with low CR
yeah you're right. i used wrong word but you got the meaning.
personally i wouldn't go lower than 9:1 unless regular pump gas was obligatory.
currently i'm on 17-18 psi on stock engine with 100 octane and water injection.
You can do that basically when you have a good ecu etc. Since i am just using the DET3 and dont have the capabilities and money to do proper dyno finetuning, i stick to low compression to not kill the engine with too much boost and a „not super perfect“ ignition map. Since the power difference is max. 5% (calculated) i am fine with the low compression and enough headroom to give it some more boost if i want to..
Cheers mate
hi sorry can you tell me how did you connect det3 to the control unit? i have been trying for two weeks and it is not receiving rpm from the cas sensor ????
