Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 6 of 6
Thread: Leaking Sumitomo All Season 18 inch tires on 107 wheels.
    May 2017
    Georgia
    2003 Z4 2.5
    I have a problem with the new tires on my Z4. Several times the tires have leaked down and I've added air. It's got to now I carry a 12 volt compressor with me. Is there any thing I can do to alleviate this prpblem? It looks like the bead of the tire is not sealing properly.
    Jan 2016
    Ca
    2001 525it
    Take the car back to the tire shop and have then inspect the valve stems-tires and rims.
    May 2017
    Georgia
    2003 Z4 2.5
    Leaking tires
    Quote Originally Posted by jclausen View Post
    I have taken one back, had it broken down, remounted. It seems when I hit a bump , bead brakes loose.
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    If that's the case, you have bigger problems. The bead should never break loose going over bumps. What size wheels and tires are you running and and what tire pressure? Have you tried spraying soapy water to see where the leak comes from, to be sure it's from the bead area?
    May 2017
    Georgia
    2003 Z4 2.5
    I'm running BMW 18 inch wheels, 107's. 18 by 8 0n the front and 18 by 8.5 on the rear. I bought the size tires recommended for the wheels. I had 2 wheels restored, one had a crack and it was welded and ground down. No problem out the restored wheels. Drivers side looked great without restoration and the both have leaked down. I did spray soap on one wheel, saw it was leaking at the bead. I had it remounted, couldn't find anything. I'm using the recommended air pressure. I ride a bit, tire light comes on and I break out my 12 volt air compressor.
    May 2017
    Georgia
    2003 Z4 2.5
    Glory be, I have been dealing with this one leaking tire for some time. I took the wheel off the car and spent and hour spraying both sides of the rim with soapy water, looking for a bead leak, nothing. I was about to give up when I decided to look at the tread one more time. Lo and behold, I saw a very tiny soap bubble. That is my small leak, 10 pounds every 2 weeks. I'll have it in the tire shop tomorrow. I've have this tire broken down in the past and they couldn't find a thing. What a relief. I'll still carry my compressor for a bit more.
  1. WTB: 18 inch tires
    By StyleLab in forum Wheels and Tires
    Last Post: 02-28-2006, 04:24 AM
  2. 17 and 18 inch Tires for Sale
    By Car Fanatic in forum Wheels and Tires
    Last Post: 09-01-2005, 02:20 PM
  3. WTB: I need one 225/?/18 inch tire
    By x2nervisx in forum Wheels and Tires
    Last Post: 03-16-2005, 02:47 AM
  4. WTB fast! - 18 inch tire!!! 225/40
    By blueIce in forum BMW Parts Wanted
    Last Post: 07-28-2003, 11:03 PM
  5. WTB 18 inch tires
    By bmw318i in forum Wheels and Tires
    Last Post: 02-17-2003, 02:27 PM
