Results 1 to 12 of 12
Thread: Service key vs. regular key
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Long story short, I tried to copy service key (which can't open the trunk) myself using blank regular key (with additional groove), hoping it will be able to open the trunk, but it still isn't opening the trunk (opens the doors fine, and I can open the trunk using remote).
    Is that expected (and service key is so different from main key and I need to order main key from dealer) or I should suspect that my trunk lock was replaced before?
    Oct 2003
    Seattle
    99 M3
    I would suspect the functionality of the service key.
    Do you have a ‘regular’ key with the EWS matching ‘chip’
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Quote Originally Posted by bluptgm3 View Post
    Service key is fine. No, I don't have regular key.
    Dec 2005
    Sarasota, FL
    98 M Roadster
    I don't have my key in front of me, but I would expect that the bitting between the ignition and trunk would be slightly different. If you hold the regular key and valet side by side, you'll probably see a difference.
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Quote Originally Posted by Vinci View Post
    I don't have a regular key to check that. Can anyone confirm that? I had impression the groove is the only difference.
    Jan 2018
    Ocala, Florida, USA
    2001 Z3 Roadster 2.5 M54
    I'd have to say my valet key and my regular keys(s) are identical except for the groove. There is a groove the length of the key on both sides of the regular keys. The valet key won't even go into the trunk lock.
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Quote Originally Posted by Andy Woods View Post
    Thanks, this is valuable info.
    Feb 2016
    Torreon, Mexico
    2001 BMW Z3 Roadster
    They’re different, valet key is meant not to open the trunk and glovebox.
    Los Gatos CA
    1987 325is, e34, Z3, e39
    They are identical, except for the groove (or side notch on a later two-track key).
    My Defu key cutting machine included a 'V' cutter. I've used it to make a deeper groove on a key blank where it wasn't deep enough, causing the key to act the same as the valet key.
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Quote Originally Posted by djb2 View Post
    Maybe I need to do that... How did you know it's not deep enough? I can put the key inside the trunk lock, it just doesn't turn.
    Los Gatos CA
    Quote Originally Posted by deni2s View Post
    We are talking about "4 track" keys, correct? Earlier BMW keys were standard side cuts, and had extra cuts for the lock cylinders used for storage.
    "4 track" keys have 1mm deep milled cuts on the four long edges.
    "2 track" keys have a center milled track on each side.
    The groove was too shallow to slide the key into the other lock cylinders -- so it acted as the valet key, inserting only in the door and ignition not the storage (glove box, center boxes, or trunk).
    My Defu key cutting machine traces, so I prefer to cut from the rarely-used valet key.
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    I think I have "2 track" key. And I can slide it into trunk lock, just can't turn it.
  1. E39 square key vs. diamond key
    By JNDaddio in forum 1996 - 2003 (E39)
    Last Post: 06-01-2018, 09:04 AM
  2. Service program reset and key programing on 96 328i
    By AHS in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-01-2014, 02:29 PM
  3. BMW service keys vs. master keys
    By Alex E24 E30 in forum 1976 - 1989 (E24)
    Last Post: 01-14-2011, 02:38 PM
  4. Ignition vs. starter vs. damaged key?
    By zasi76 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-24-2008, 11:16 AM
  5. Service lights persist without key in ignition
    By Nic01101011 in forum 1983 - 1991 (E30)
    Last Post: 03-23-2008, 04:06 PM
