Results 1 to 25 of 31
Thread: Question about brake master cylinder
    Dec 2013
    Houston, TX
    "96 850
    Sorry to make another thread but I wanted to be absolutely sure about this: can a 7 series master cylinder be used in a 1996 850? I've heard it can and that it cannot on the forum... can anyone give a definitive answer? Using the 7 series part would save me like $700 so... yeah.
    Much appreciated,
    Ash
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    The E32 master cylinder only works on M70 cars, since the bolt holes are different at the booster, but otherwise it works just fine (for M70's)
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    May 2013
    Stamford, CT
    1991 BMW 850i
    Wrote this for the DIY section when I changed mine (a 1991). But like TxGR8 says, it could be different for anything but the M70 (plus I just noticed I have 666 posts, so I have to do one more so the devil doesn't come after my car).
    https://www.bimmerforums.com/forum/s...BMW-850i-(e31)
    My Cars - 1991 BMW 850i - mine for fun, 1993 Saab 900c - mine for fun, 2008 Lexus is250 - my daily driver, 2003 Dodge Durango - my wife's, 1994 Acura Legend - gave it to kid
    Dec 2013
    Houston, TX
    "96 850
    Thank you guys, this forum is amazing
    Dec 2013
    Houston, TX
    "96 850
    Is this the right part for a 1996?
    https://www.fcpeuro.com/products/bmw...0i-34311160197
    It says it works for all years?
    Dec 2007
    Dallas, TX
    The early cars (M70) have a different bolt mounting pattern to the booster than the later (M73) cars. It will only work on one or the other. The later cars have the same bolt pattern as the 840’s.
    The part number of the MC that you posted will only work on M70 & S70 engined cars (check the part number on realoem)
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Trouble is.. .RealOem doesn't list the master cylinder at all for the later cars
    IF it is indeed the same as the later 840's, The part number for the right one is 34311162914
    But looking at the diagrams, it sure looks like 34311160197 does fit the M73 cars. You sure they are like the 840's?
    '91 850i 6sp (mint) (sold)
    Dec 2010
    Winnipeg
    1992,1993 M5, 1990 850i,
    I purchased an E32 Master cylinder from Rock Auto for about $100. As stated above it will only work with M70 cars (mine is an 1990 850i). I used PabloRock's procedure as a reference. Enerything worked like a charm and I noticed no difference in pedal pressure or braking performance....
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    If both the master and booster are changed to an M70 version, can they be used in an 840?
    What "thumbs up" really means
    Dec 2007
    Dallas, TX
    Quote Originally Posted by toomanyparts View Post
    The outgoing ports are slightly different. You would need to get the hardliners redone also.
    Mar 2011
    Thanks. Sounds like it is cheaper just rebuilding the booster and replacing the 840 specific MC.
    Dec 2013
    Houston, TX
    "96 850
    Thanks guys. So this is the right one:
    https://www.ecstuning.com/b-genuine-...r/34311162914/
    Sep 2008
    Santa Barbara
    Quote Originally Posted by Guts1200 View Post
    That IS the right one for the 840's... I'd trust Steffen and order it for the M73
    But considering it is rather pricey, take a close look at the one actually in your car. The other ones have mounting holes pretty much centered horizontally with the bore, the 840 ones look like the pic on ECS's site. There's enough of a difference to see
    Dec 2007
    Dallas, TX
    840, if I remember correctly, has three mounting holes, 1 on each side and the third on the bottom. I highly recommend that you triple verify what you order from anyone other than the dealer. Buying a water pump years ago for an 850, turned out to be incorrect because the third parter vendor thought the 750 water pump is identical to the 850 ( both being mounted on the M70), this is not correct, as the 850 has an extra port for the overflow hose. Most of the E31 parts are specific to that model. Good luck and let us know how it turns out for you.
    Mar 2006
    Harrisburg, PA, USA
    x5, 640i, 850Ci, 850CSi
    This is the correct one for an M73 850Ci: https://www.ecstuning.com/b-genuine-...r/34311160197/
    Mike Barrett
    94 850CSi, Hellrot over silbergrau dunkel/silbergrau hell
    96 850Ci, Oxfordgrun over silbergrau hell
    Dec 2013
    Houston, TX
    "96 850
    Sorry for the late reply... I've been sick the last few days and have been just laying around doing the bare minimum. Finally starting to feel better...
    Mbarrett - I cant seem to get through to your link... it redirects to something called viglink and I'm unable to get past that to the ecstuning site. Am I doing something wrong?
    I noticed that it says you own a 96 in your signature. Do you know that the brake master cylinder you're recommending is the correct item from experience?
    Mar 2006
    Harrisburg, PA, USA
    ECS tuning sends you to an ad before you can see the actual item. When you click on the link in my post, look for the link that says "skip these deals & continue to ecstuning.com". That should take you to the part in question.
    Mike Barrett
    Sep 2008
    Santa Barbara
    ECS tuning isn't doing that, Bimmerforums is...
    Dec 2013
    Houston, TX
    "96 850
    Ha! I don't know how I missed that! Thanks!
    So, that model # is the one I started with but txgr8white is saying it doesn't work for cars with a M73. Are you sure that's the right part? Have you used it before? If that one works, I should be able to use the 7 series part (I think).
    PS - cartoonz, the fcpeuro link in this thread doesn't redirect like that
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    this viglink is really disturbing, and difficult to escape. You can go to the viglink opt out site and click there opt out https://www.viglink.com/opt-out/ click disable. But sooner or later you will have to go there again and opt out, a never ending story. I tried adwcleaner, but it did not find anything.
    some info https://www.2-spyware.com/remove-viglink.html
    Dec 2013
    Houston, TX
    "96 850
    Since it seems like no one knows for sure, I think I'm just going to order the part that everyone has marked as working for my car. That way, if it doesn't fit, hopefully they will at least allow me to return it without penalty.
    Mar 2011
    Can you not read part no. from existing unit?
    Mar 2006
    Harrisburg, PA, USA
    I’m sorry it’s taken me so long to respond to this, but I’ve been away from my car and couldn’t check. However last night I checked my 96 M73, and it’s definitely a three bolt master cylinder, which is the same as the 840 master cylinder I believe, but is definitely not the same as the M70 version; nor is it the same one as shown as applicable to all 850s on the ECS website. Their information in that regard is incorrect.
    Mike Barrett
    Dec 2013
    Houston, TX
    "96 850
    Thank you for checking Mike. I called BMW (probably what I should've done from the get-go) and they said this is the correct part #:
    34331161950
    They looked it up based on my vin so it should be right. Most websites also show that it fits 840s and late model 850s. Found it at BMW of Cincinnati for $824.
    Edit: made a mistake, this part # is actually for the brake booster.
    Mar 2011
    The ETK is wrong sometimes as well (see PS filter for later cars).
  1. brake master cylinder question
    By zdr262 in forum 1983 - 1991 (E30)
    Last Post: 10-20-2018, 12:14 PM
  2. Brake master cylinder question
    By Strelok in forum 1983 - 1991 (E30)
    Last Post: 03-09-2010, 08:45 AM
  3. Brake Master Cylinder Question Help!!!!!!!!!
    By Shawno in forum 1991 - 1999 (E36)
    Last Post: 01-07-2010, 05:22 PM
  4. Brake Master Cylinder Question. Please HELP!
    By BMDubz in forum 1996 - 2003 (E39)
    Last Post: 07-08-2008, 11:51 PM
  5. E36 M3 Brake Master Cylinder Swap Question
    By BimmerBoy in forum 1991 - 1999 (E36)
    Last Post: 08-20-2004, 09:45 AM
