Results 1 to 3 of 3
Thread: 95 M3 misfire/backfire on acceleration?!
    Mar 2018
    Laramie, WY
    95' M3
    Hello, new to bimmerforums...
    I just put almost 2k into my car having the clutch replaced and all new tires put on only to get less then 400 miles and it breaks down again! Only this time its a whole new issue.
    So to start idk if this is relevent or not but i was stupid and did the water in the exhaust thing to make it sound different a day or two before the misfire/backfire/different idle came up. When I parked the car is was running great. and a day or two later when i started it to leave my house it was idleing different... and when i when to drive away from my house it starts backfiring thru my exhaust like gun shots! i turned around and parked it.
    Since then i have
    ~replaced the crank sensor that was almost rubbed in half by the fan pulley - no difference.
    ~I disconnected the exhaust from the header to see if maybe a cat or resonator collapsed and was causing to much backpressure - no difference
    I am probably going to order a new coil pack and see if one is going put intermittenly. Just wanted to touch base here and see if anyone else has had this issue and figured out what it is??? Any info or guesses will be greatly appreciated!!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    you posted in the Forum Software Questions & Suggestions, I will move it to the E36 M3 forum
    Jul 2004
    Indianapolis
    '86 E30S50, '12 VW GTI
    Have you checked for engine error codes?
    Does the backfiring occur when freely revving, or slowly accelerating while driving? Or is it only when the engine is under load?...that’s when my backfiring occurs.
    Did you do any other work besides replace the clutch?
    I’m chasing the exact same problem on my S50 that occurred right after replaced the head gasket and rear main seal.
    Mine is mostly throwing a cam position sensor error code. I’ve since replaced both the cam and crank position sensors with Genuine BMW sensors, and I still get the code and backfiring.
    Read my other recent post in this forum and see if it sounds like your issue as well.
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn
    '03 540i M-Sport (sold)
    '08 Jeep SRT8 (sold)
  1. 95 M3 Misfire
    By DTFE30 in forum 1991 - 1999 (E36)
    Last Post: 05-28-2014, 11:32 AM
  2. 95 m3 misfire at idle, up to about 2.8rpm
    By bmwe36mike in forum 1992 - 1999 M3 (E36)
    Last Post: 07-10-2012, 11:00 AM
  3. accelerator pedal for 95 m3
    By MR E30 in forum 1991 - 1999 (E36)
    Last Post: 11-10-2008, 07:07 AM
  4. misfire 95 m3. no CE light.
    By notdownfornj in forum 1992 - 1999 M3 (E36)
    Last Post: 05-21-2007, 04:41 AM
  5. acceleration for a 95 M3
    By cbr389 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-06-2005, 06:08 PM
