Results 1 to 18 of 18
Thread: '00 323Ci steering rack
    Jan 2018
    Sachse, TX
    several
    Any recommendations for replacing as far as brand, etc.? Definitely looking for refurb/rebuilt.
    Sent from my mobile device using Tapatalk
    Jeremy
    2000 323Ci Titansilber Metallic cabriolet
    Jan 2017
    USA
    E21, E46
    BMW genuine... maybe others have had better experiences with non-genuine however everyone I've ever spoken to that went a different brand had issues.
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by RobertDenali View Post
    I have heard similar. Genuine ZF remanufactured/rebuilt. I was also looking at LKQ, but they would be used. Also, not sure what would be missing as far as boots, etc.
    Jeremy
    Jun 2012
    New Mexico
    2003 328i
    Either spend a lot for a genuine replacement or get a good used rack and replace the boots. I have had good luck with used racks. A remanufactured rack with unknown quality components is more money for a lower grade part.
    Same goes for engines and transmissions. I would much rather have a good used factory engine than one a person of unknown competence had taken apart, reassembled with machine work that was almost certainly worse than what BMW did at the factory and with parts almost certainly of lower quality than the originals. And they go for more money too.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by MarcoZandrini View Post
    Thank you! How do I know TRW or ZF?
    Jeremy
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by JCC511 View Post
    Maybe I need to call rackdoctor.
    Jeremy
    Jan 2018
    Sachse, TX
    several
    No one? Meant to call them today.
    Jeremy
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    ZF actually bought TRW. The original rack will have the ZF logo if it’s a ZF rack.
    Jan 2018
    Sachse, TX
    several
    I saw on E46fanatics something about the TRW is overboosted. Not sure if that is good or bad. Where would the logo be?
    Jeremy
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Overboosted racks were installed during model year 2001. My 2001 330Ci (7/2000 build) had this rack. It was made by ZF. Go to rack doctor and see what’s offered. You can install what was erroneously labeled the “ZHP” rack if you want. It’s a bit more expensive than the other racks.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    I'm not sure why you're replacing the rack for a rotational scraping noise when the car is sitting still....
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by dhurley34 View Post
    The noise I was originally hearing was the tensioner pulley, I believe. Serpentine belt popped today and apparently I lost my power steering pump pulley somewhere along the way. Steering rack symptoms I figured were difficulty steering and reduced steering radius. May have been the power steering pulley was loose. Will see once I am finished putting things back together.
    Called rack doctor and they said ZF and TRW are interchangeable. Main way to tell the difference is ZF has the metal plate, which mine does.
    Jeremy
    Jan 2018
    Sachse, TX
    several
    I changed the belts and replaced the missing power steering pump pulley. Less noise and possibly steering is now good. Overheating and hoping it is nothing serious as I know it can be with the E46.
    If it is the head gasket, do I need to do the full kit or just the gasket itself? $60ish vs $300+ on more involved kits. Not sure if this means the engine is just gone or if replacing the gasket is the fix. I realize it may not be an easy task.
    Jeremy
    Aug 2014
    Lawrence Kansas
    If it is a head gasket, you will need to have the head AND the block machined to be true again. At that point, you would be better off replacing the engine with a used one.
    Jan 2018
    Sachse, TX
    several
    Praying crisis is averted. Added some coolant and ran stable tonight. May add more tomorrow as it seemed like it could take more. It is possible I did not bleed the system well enough after the last flush which was recently.
    Jeremy
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Go to E46Fanatics and read Mango’s sticky on the cooling system. Read the properly bleeding procedure.
    Jan 2018
    Sachse, TX
    several
    Jeremy
  1. 2000 323Ci steering rack issue
    By kampy in forum 1999 - 2006 (E46)
    Last Post: 05-03-2017, 03:48 PM
  2. Steering rack
    By autox320 in forum 1991 - 1999 (E36)
    Last Post: 07-17-2015, 08:23 PM
  3. BMW z3 steering rack $125.00 OBO - SOLD
    By Jakedexter in forum Suspensions, Springs & Shocks
    Last Post: 05-05-2015, 11:28 AM
  4. Looking to buy a steering rack - 92-00?? Is that right?
    By Topher91 in forum 1999 - 2006 (E46)
    Last Post: 05-05-2006, 11:02 AM
  5. Popping in steering rack?
    By triksterut in forum 1991 - 1999 (E36)
    Last Post: 11-17-2001, 09:54 PM
