Results 1 to 14 of 14
Thread: Turbo 2003 z4 build
    Sep 2018
    gilbert, arizona
    2003 BMW z4,1979 TransAm
    Turbo 2003 z4 build
    This is my first European car ever, i come from an oldschool muscle car background so this is something new to me. Ive always had a desire to add more power and cant sit still. Anyways, here is what ive been researching and any help or adjustment is awesome.
    Im using this kit as a basis for the turbo manifold and the piping.
    https://www.ebay.com/itm/BMW-E36-92-99- ... 1657423599
    the turbo is immediately going to be tossed and a nice size garret thrown on. Did i get the engine correct? our cars have the m52 i think...
    next will be meth injection with head bolts and ill leave it at that. Ill have my tuner do a low boost setting such as 6 psi for around a 60hp gain to putt around town with and a 16 psi tune for straight line racing and possible autocross. (dont really like alot of boost kicking in when im canyon carving or autocrossing). This is where the head bolts and meth injection shine so i dont blow out the heads and cause pre-detonation.
    Thoughts? Not sure how you guys feel about stupid builds here but i think it might be fun to build a little rocket.
    nice meeting everyone!
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Your engine is an M54, either 2.5L or 3.0L.
    Sep 2018
    gilbert, arizona
    wouldn't the kit still fit?
    Apr 2006
    Minnesota eh?
    86 325es
    should be close, I think the exhaust ports are the same or similar.
    Jun 2005
    New England
    Probably. The eBay kits typically don’t even fit the car or motor they are designed for very well. The Z4 may have less room. We don’t see many turbo Z4 or turbo M54 so the path you are on is not as easy. The aluminum block M54 may not be as durable with boost. Just an overheat can pull the bolts right out of the block.
    Jan 2017
    Keokuk, Ia
    m50 turbo w123, 4g63 e30
    For what it's worth, I've used the same cxracing top mount t3 manifold on my e36, my M50 swapped w123 Mercedes, and it's now on my Z3. I've had to weld up cracks several times but as far as fitment goes it's luckily fit everything I've attempted to use it on. It's hard to say for sure if it will fit a z4 without trying it though
    Sent from my Pixel 2 XL using Tapatalk
    Feb 2013
    Canada
    2004 Z4R 06&12 Cooper S
    The kit may or may not fit
    The issue is the ECU tuning.
    04R 3l 6 sp VF SC, custom ducting, alphaN, 2.62 pulley, multiport WMI,Severn Tuning(Pokeybritches), Tial BPV,Ceramic header, magnaflow section 1, SS race muffler/y-pipe, megan mounts,42 design catch can, CDV delete ,custom strut bar,3.91 LSD, H&R bars, Hotchkis links.Eibach Pro Kit,Koni Yellows.Megan camber arms. Carbon interior,SSK,UUC lines.CF aero. Poly bushings.
    Sep 2018
    gilbert, arizona
    yeah, can anyone recommend a way to tune the ms45 ecu? seems like a powergate 3 might work?
    Vancouver, B.C., Canada
    '97 M3
    I’d like a high powered turbo Z4M coupe please. Make it an ‘06 or ‘07 in silver or maybe charcoal. Yum!
    Phoenix,AZ
    99' 323is, 99' 328is
    ^^^I just picked up a z4m not a month ago, black with 44k miles. But is there tunning for turbo?
    Sep 2018
    gilbert, arizona
    yeah, there is no way to crack this open without swapping the ecu to the ms43. Holy crap that was a whole lot of researching for a whole lot of nothing.
    Feb 2013
    Canada
    Quote Originally Posted by lonewolf1828 View Post
    There are things in the works for "cracking" the ECU or going stand alone.
    Exciting times ahead methinks
    Nov 2011
    Greece
    you'd better convert to ms43.
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    I recall seeing a thread on ZHPmafia about tuning the MS54
    Sent from my G8141 using Tapatalk
  1. Z4 E85,E86 2003 Z4 3.0 For sale
    By Lil Tippy in forum Z3,Z4,Z8 Classifieds
    Last Post: 09-04-2010, 10:53 PM
  2. Z4 E85,E86 FS: 2003 Z4 2.5i 5-Spd Sport/Prem 51.5k miles $14,000 (gauging interest)(VA)
    By Enemy in forum 3 series & Z Series
    Last Post: 07-16-2010, 11:28 AM
  3. Z4 E85,E86 Need ash tray door for 2003 Z4
    By Hermosa in forum BMW Parts Wanted
    Last Post: 06-13-2010, 01:46 AM
  4. Z4 E85,E86 2003 Z4 3.0i 6 Speed with every option Sterling Gray/Black $15,500
    By Mooseiah in forum 3 series & Z Series
    Last Post: 05-29-2010, 12:18 AM
  5. Z4 E85,E86 2003 Z4 3.0I 26000mi
    By grg600 in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-20-2010, 10:17 AM
