Results 1 to 11 of 11
Thread: '00 323Ci front drive axle maybe
    Jan 2018
    Sachse, TX
    several
    The boot on the drivers side is split open and may have broken worse today. I have been hearing a rattling sound and more recently a winding sound that was on that side. There was a shattering/breaking sound this evening while driving. Turning radius now seems to be more limited. Will be looking at DIYs and figuring out next steps. Any advice on brands or recommendations are appreciated.
    Sent from my mobile device using Tapatalk
    Jeremy
    2000 323Ci Titansilber Metallic cabriolet
    Jan 2018
    Sachse, TX
    several
    Looks like it is this.
    https://www.realoem.com/bmw/enUS/sho...diagId=32_1169
    Jeremy
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The constant velocity joint is likely toast. That means it’s time for a new axle. If you plan on keeping the car for more than a year you should buy an axle made by GKN. It’s tge supplier to BMW.
    Jun 2005
    CT
    18 LCI M2 BSM MT
    323Ci doesn't have front drive axles. There were no AWD E46 coupes. What you are showing in the realoem link is a steering rack (which is maybe what you meant just with the wrong terminology). A picture of the damage would help diagnose.
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by CT Sean View Post
    Yes, I should have known it was not a drive axle. Will send a pic. Wondering if I need to replace the rack or repack the boot.
    Jeremy
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What are the symptoms? Is the rack leaking fluid?
    Jan 2018
    Sachse, TX
    several
    Not leaking fluid that I have seen, though I should check the level. Difficulty steering and definitely reduced turning radius. The boot on the drivers side is torn open.
    Jeremy
    Jan 2018
    Sachse, TX
    several
    https://r.tapatalk.com/shareLink?url...9&share_type=t
    Jeremy
    Wisconsin
    98 328IS 03 325xi
    Quote Originally Posted by JCC511 View Post
    The boot is just for protection, doesnt 'hold' anything.
    Gave away my BMWs, driving a VW and an Audi now.
    Dec 2013
    Chicagoland area
    EXOTICS
    Yes, it may be the steering rack in the link you posted.
    https://www.realoem.com/bmw/enUS/sho...diagId=32_0940
    Or,
    only require replacement of the tie-rod assemblies.
    The rubber boot prevents contamination of the rack and assembly lubricant.
    As was mentioned, they are not referred to as axles,
    but as tie-rod assemblies, which consist of an inner & outer tie-rod, actuated by the steering rack-turning the wheels left/right.
    Jan 2018
    Sachse, TX
    several
    Thank you both. Some boots hold grease and I thought this may have been the same. Good to know. Had the serpentine belt break possibly due to the power steering pump pulley breaking. Since I have replaced the pulley and belt, steering has been fine. Still may need some things repaired/replaced, but working well as far as I can tell.
    Jeremy
  1. Front drive-axle bellows for iX
    By DanielOrdal in forum 1988 - 1996 (E34)
    Last Post: 09-16-2014, 08:58 AM
  2. 2003 x5 front drive axle leaking
    By neilmason418 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-07-2011, 08:46 PM
  3. Front drive axle
    By Pdxix in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-05-2010, 10:04 AM
  4. Removing 2001 325xi front drive axle
    By gordo325xiwagon in forum 1999 - 2006 (E46)
    Last Post: 01-14-2008, 06:56 PM
  5. Installing new rear springs, do I NEED to remove drive axle??
    By pete1787 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-14-2002, 09:42 PM
