Results 1 to 25 of 27
Thread: What happens when you use up all your traction control?
    Apr 2015
    Sacramento CA
    2001 Z3 Roadster
    So I was driving today, curvy roads. Nothing major. All of a sudden my dsc and brake light come on. I thought maybe my pads were low and that was part of the sensor telling me.
    I did shut the car off and go into a store. I came out and started the car, both lights went off, dsc was operating normally.
    Can Some one shed some light on this for me? Or point me to a thread that pertains to this?
    Thanks y'all.
    People I owe beverages to, lokijibber
    Jul 2004
    Houston, TX
    36 Cylinders
    It needs a diagnostic scan to see what errors are present.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Apr 2015
    Sacramento CA
    2001 Z3 Roadster
    Since the lights went off, I'm assuming they didn't get stored? Or are they stored for a certain amount of key cycles?
    Jul 2004
    Houston, TX
    36 Cylinders
    Codes usually get stored, so it should have a history of what happened. Usually a yaw sensor or a wheel speed sensor may have gone rogue.. but it can be other things, which is why a scan should be done first. Too many possibilities.
    -Abel
    Apr 2015
    Sacramento CA
    2001 Z3 Roadster
    I will see if my reader will show something.
    Thanks for the responses.
    Have you refilled the traction control fluid recently? 1999 and earlier models need ASC fluid, later models need DSC fluid (or compatible)
    Oct 2013
    Rock Hill, SC
    2000 BMW M Roadster
    Quote Originally Posted by BimmerBreaker View Post
    I upgraded from the stock ASC fluid to Elmer's. Now I can practically drive upside down!
    RI
    2008 M5, 1995 540i
    Is your rear end diff mount bad? I had some similar weird errors because my rear diff mount was dying.
    Current Cars
    2008 BMW M5 6 spd
    1995 BMW 540i 6 Spd
    2016 M4 Cabrio 6 spd
    2017 X5 35d MSport
    2017 i3 94ah Rex
    Former Cars
    2013 135i MSport Cabrio DCT
    2012 BMW X5 35d Sport
    2000 BMW Z3 2.8 Roadster MSport Impala Brown
    1992 BMW 535i 5 Spd
    2011 BMW X3 2.8i MSport Alpine White
    1995 BMW 530iA Artic Silver
    1986 BMW 635CSi Bronze Mettalic
    2009 Dodge Ram 2500
    Nov 2011
    Croatia
    1992 BMW 850i 4spd
    Had a similar problem on an e31 - mine was a siezing ABS pump. Turns on the DSC light at times and the ABS lights sometimes as well.
    Happens more often the less you drive the car and if you drive it so that ABS does not activate. Hook the car up to a diagnostic system and cycle the pump as a cure/prevention.
    Washington, D.C.
    S54 e36/8
    set up INPA and ISTA to figure it out...use Abel's guide in the diagnostic thread.
    Apr 2015
    Sacramento CA
    2001 Z3 Roadster
    Not sure if serious.
    So I need AC/DC fluid?
    Quote Originally Posted by bagekko View Post
    I recently put in poly sub frame bushings, mount was good.
    Quote Originally Posted by fmcfad01 View Post
    That's a bit above my pay grade.
    Aug 2017
    I have never heard of special ASC/DSC fluids, as far as I know the system operates with regular brake fluid (DOT4) taken from the brake fluid system in the car.
    SF Bay Area, CA
    BMWs: 1; MINIs: 1
    The AC/DC fluid goes in the reservoir next to the blinker fluid.
    I like the unicorns.
    '99 Z3 Coupe - Jet Black/Black (1-of-114)
    '99 M Coupe - Estoril Blue/Black (1-of-82)
    '03 540iT - Sterling Gray/Black (1-of-24)
    '16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
    AC/DC is great stuff, compatible with ASC and DSC. Run the stuff high in Angus Young for the best traction control module protection possible
    PRICE CUT on ALL FABRICS
    A Forested Region
    2002 Z3 3.0
    I tried AC/DC fluid and was thunderstruck. The difference shook me all night long. I used to be in the red, but now I am back in black. If I keep this up, I’ll be on the highway to hell. Replacing the fluid is a dirty deed, but it’s done dirt cheap.
    OP, you may have a bad yaw sensor under your feet or some dirty malfunctioning speed sensors at the wheels. A few years ago, I ruined the yaw sensor by steam cleaning my carpet. The symptom was the DSC and BRAKE lights would light up and stay on if I took a tight turn. They would cycle off at shut down and not light again unless I was cornering near the limit. The fix was a new sensor and a clearing of the codes. To check the codes, you neeed to use the socket under the hood, not the obdii port. Good luck.
    Steve
    '02 Z3 3.0i
    Apr 2015
    Sacramento CA
    2001 Z3 Roadster
    It's definately a long way to the top, if you wanna rock and roll. Considering the social pages say I've got the biggest balls of all.
    I guess if you want blood, you got it.
    You guys are too much. Hopefully this weekend I will have time to see if my reader will see the fault.
    Jul 2012
    Pingree Grove, IL USA
    2006 X3 3.0, 2000 Z3 2.3
    I had similar issues with an X3. Turned out to be a bad alternator creating lower than normal voltage while driving. The battery was good and it had no issues starting but it triggered the warning lights from time to time.
    Jan 2016
    Kyoto
    E92 M3, E36 M3 evo, Z3
    I always drive with asc&abs off, so I wouldn’t know how it behaves with them on... but boy is it a joy to drive sideways on wet roads.
    Jun 2005
    Franklin, TN
    00 Z3 2.3
    Quote Originally Posted by kyrix1st View Post
    How do you turn off ABS? And why?
    Apr 2015
    Sacramento CA
    2001 Z3 Roadster
    Quote Originally Posted by Matt Day View Post
    Push the button.
    There is a button on the console that turns off the ABS. The light on the dash will light up and stay on.
    Aug 2017
    That turns off ASC, not ABS.
    Jan 2016
    Kyoto
    Just remove left front wheel speed sensor and ASC/ABS will not work.
    I do this because BMW ABS cuts in too early for any serious late braking into a corner. Also can't get the back end out because I can't lock the rears on gymkhana sessions either..
    My car har has ABS and DSC disabled. Bought it like that
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    yank on the E brake that's how Bond James Bond does it
    Apr 2015
    Sacramento CA
    2001 Z3 Roadster
    Quote Originally Posted by me77 View Post
    Yeah, I wasn't paying attention.
  1. what happens if I use 87 octane and not Supreme (91)??
    By a1yola in forum 1991 - 1999 (E36)
    Last Post: 05-24-2005, 05:49 PM
  2. What happens if you use 87octane with a dinan chip?
    By NewToTheForum in forum 1991 - 1999 (E36)
    Last Post: 05-22-2005, 10:58 PM
  3. What happen if I use a 80ah battery in M3?
    By Lanchai in forum 1992 - 1999 M3 (E36)
    Last Post: 03-03-2004, 10:48 AM
  4. What happens if you use normal oil instead....
    By Wasiq in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-06-2003, 09:10 PM
  5. what happens when you use cheap gas with chip?
    By sage in forum 1991 - 1999 (E36)
    Last Post: 06-19-2001, 12:26 AM
