Results 1 to 6 of 6
Thread: Gear lever confusion
    Jul 2018
    Vancouver, BC
    1988 BMW 735iL
    I'm replacing the gear selector cable in my e32 and I'm weary that if I engage the cable to a different gear than what is showing on the gear selector, then I'm going to have an issue. So I'm trying to put the gear selector (in the car, and underneath, #23) into park. The plastic cylinder that runs the length of the shaft of the selector (#13) doesn't want to raise when I pull the handle of the selector. Thus I cant change gears without lifting up the plastic bit without a screwdriver and moving it like that. Any ideas? My battery is dead but I think this issue is unrelated to the solenoid. Correct me if I'm wrong! My main question is whether #15 in this diagram https://www.realoem.com/bmw/enUS/sho...51#25161219149 is supposed to go into the top hole of #13.
    Second issue: Driver door lock. I just replaced the actuator and it made a difference in how badly the lock is making it seem like it wants to work, but nothing much otherwise. I cant raise or lower the lock by hand, too stiff, though the central locking is working fine, as the rest of the door locks respond accordingly. I've looked at all of the components in the door for a decent amount of time, and nothing looked out of place, though I'm unfamiliar.
    Thanks in advance.
    May 2012
    Boynton Beach, Florida
    1990 735I (E32) M30
    Click here to Shoguns page. http://twrite.org/shogunnew/topmenu.html Go to fixes, then check body/repair shift knob. Then check Doors to check to resync your door locks.
    This might also help you. I had to replace my shift mechanism a couple of years ago. Check this thread for some good pictures.
    http://www.bimmerforums.com/forum/sh...Failure-SOLVED
    1990 735I (Auto) E32 Feb 1990 to Present
    1996 Z3 Roadster (5 Speed) E36/7 Jan 1999 to Dec 1999
    1983 733I (5 Speed) E23 April 1983 to Feb 1990
    https://www.youtube.com/watch?v=2d4tHoHGaJo
    https://1drv.ms/v/s!Av20xCMMocSsyEpl...h_oOk?e=ekIcAT
    warwick RI
    E30/E32/F25
    If your trying to get the car into a gear as its stuck in park ... I think that’s what you mean ? Sitting in drivers seat there is a metal hook inside the shifter assembly (under #7 in the diagram) lift that hook up and pull the shift handle and it will release, You can only see this hook from the drivers side. For the cable I usually put the car in reverse and the trans in reverse and install the cable but to be honest the cable has very minor adjustments if any so you should be able to put the cable in blindly and adjust accordingly
    Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
    G/F’s E34 92/ 525iT + F48 18/ X1
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Cable installation and adjustment is described in detail in the workshop manual https://www.bmwtechinfo.com/repair/main/
    Door locks: after the small grommets all in place? https://www.bimmerforums.com/forum/s...light=grommets
    Jul 2018
    Vancouver, BC
    1988 BMW 735iL
    I didn't have to remove any grommets to replace the actuator. To check them, I cannot tell what the photo on RealOEM is referring to. Do you happen to have a photo of these grommets on the car?
    Would the grommets be symptomatic of me being unable to manually lock and unlock the door?
    Jan 2005
    Japan
    see this link https://www.bimmerforums.com/forum/s...light=grommets
    Would the grommets be symptomatic of me being unable to manually lock and unlock the door?>>yes, in case of my car it was the problem, the grommets are holding the links in the lock system, and when these grommets are old and crumble away the system does not work anymore.
  1. Cheap vs expensive vs OEM short shift gear lever
    By S1Driver in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-15-2007, 01:37 AM
  2. Shift Knobs (Gear Levers) - Help Please
    By p1m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-03-2007, 11:28 AM
  3. E46 gear lever problem
    By audi955 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-05-2006, 04:55 PM
  4. e 36 M gear lever...
    By jrkoupe in forum BMW Parts Wanted
    Last Post: 03-29-2006, 02:36 PM
  5. Gear lever light always on (illuminated) ??
    By DirtyConecticut in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 06-04-2005, 03:39 AM
