Results 1 to 2 of 2
    Mar 2013
    Alpharetta
    1998 z3
    Cooling system mystery
    03 X5 3.0
    recurring overheating problems. Changed bad waterpump, thermostat, viscous fan and coolant reservoir.
    drove it around locally with scanner cooler temps in the mid to high 90’s. Seems normal.
    did about 10 miles at highway speed today, same temp readings. Seems good.
    Popped the hood afterwards and noticed fresh coolant around the reservoir, could not determine exact source but seems close to top of tank.
    Mysteriosly, about 45 mins later I looked at it again and both of the coolant hoses are collapsed. Normally they are tight.
    What does that say?
    Will do a cylinder leak down and block test soon.
    jb
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    Could it be a bad coolant tank cap? and has the system been properly bled?
    Regards,
    Brian
    Cave Creek, AZ
  1. Hey, another cooling system bleed mystery thread.
    By Ring Rat in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-27-2018, 04:34 PM
  2. Cooling system mystery "beads"
    By JoshBMX in forum 1991 - 1999 (E36)
    Last Post: 03-09-2015, 12:05 PM
  3. 89 e30 cooling system mystery post cylinder head swap! Got me stumped! (kind of...)
    By Gatopescado in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-02-2014, 06:03 PM
  4. Mystery cooling system component?
    By 777mech in forum 1976 - 1989 (E24)
    Last Post: 03-05-2012, 05:21 PM
  5. Need help, Strange cooling system problem
    By Stylin in forum 1991 - 1999 (E36)
    Last Post: 06-02-2001, 04:00 AM
