Results 1 to 11 of 11
Thread: 93 e36 325i no 2nd gear
    Sep 2018
    Portland, OR
    1993 bmw 325i
    So I bought a 93 325i for $600 with a supposedly bad clutch. I replaced the hydraulics and the clutch is fine but there’s no 2nd gear. I don’t hear any grinding or anything while driving it but 2nd gear just isn’t there. Like the car is still In neutral while in 2nd. All the other gears work great. What could be the issue? Has anybody had this problem before? I searched google but didn’t find anything solid.
    Anything helps, thanks!
    Jan 2016
    Ca
    2001 525it
    I once brought a tripumh spitfire for $75.00 drove it home never found 4th until i drained the trans fluid at first nothing came out then i shoved a screw driver into the oil drain hole and a bunch of metal came out, there was 4 th gear maybe you should check the oil.qq
    Apr 2014
    UK
    1995 BMW 328
    Reality is the box is coming out whether to fix or replace. Have a look it is nothing daft like a fouled lever underneath and then get a spare box and swap at leisure
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Aug 2009
    sunnyvale CA
    325is
    The Getrag 250 for ~95? had some bad machined syncros for the 2nd gear. A service recall was offered to some original owners according to my dealer.
    I could not keep the car in 2nd gear it kept popping out.
    Sep 2018
    Portland, OR
    1993 bmw 325i
    It’s not popping out it just acts like neutral. No engagement of the gear what so ever. No resistance. I can just slide it in with the car running and not pressing the clutch. It’s the strangest thing I’ve ever seen.
    I’m going to crawl under and check the shift bushing and take pictures. If nothing looks off I’ll pick up another trans and swap it.
    Apr 2015
    Tennessee
    1998 BMW 328i
    If all the other gears work as they should, I'd say its a very high possibility that your second gear has been destroyed
    SanDiego,Dallas,Miami,Orl
    Too Many
    Sounds like you need another trans. If youre gonna drive hard (or for longevity) Upgrade to the zf 5speed from the 97+ 328/528/M3. The older getrag can be found for cheap though...i once went to a junkyard and they wheeled out a decent looking getrag for only $50. They even loaded it into my truck so i wouldn't get dirty!
    Current lineup: 99 BMW M3vert (project) , 05 Mazda RX-8, 04 Mercedes CLK320, 03 Chevy Express 1500 (work van).
    Previous rides: 07 Mazda RX-8, 92 BMW 325iNV, 94 BMW 325iC, 94 BMW 325i S50 M3 clone, 84 Mitsubishi Cordia Turbo, 84 Mazda B2000 lowrider, 88 Toyota Tercel, 88 Honda Accord, 93 BMW 318i, 95 Nissan Altima, 89 Toyota Camry, 95 Mitsubishi Eclipse GS-T, 93 BMW 318is, 84 Toyota Tercel, 96 Mitsubishi Eclipse GS-T, 97 BMW 528i 1JZ swap, 94 Acura Integra 4dr, 88 Toyota Corolla Wagon, 97 VW Jetta GLS, 86 Toyota Corolla AE86 4A-GZE supercharged engine swap, 94 Lexus LS400, 95 Isuzu NPR Turbo, 01 Suzuki TL1000R, 98 Honda CBR600F3, 99 Yamaha R6 and countless other dirt bikes and toys
    Sep 2018
    Portland, OR
    1993 bmw 325i
    I have contemplated the ZF upgrade if I have to swap the transmission. I’ve been combing this thread for a definitive parts list.
    http://forums.bimmerforums.com/forum...to-Manual-Swap
    Can I reuse my slave cylinder or do I need to change it and the master cylinder?
    Apr 2014
    UK
    1995 BMW 328
    Quote Originally Posted by Mrgangle View Post
    Could even be a broken or jumped off selector fork. However, as I said it is coming out either way. If Getrag is cheap a quick swap is better than a time consuming fix
    Sep 2018
    Portland, OR
    1993 bmw 325i
    Climbed under it today. Don’t feel a crazy amouny of slop or anything so I guess I’m searching for another transmission. Thanks guys
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    My getrag lost 2nd gear. Then I put fluid in it for what I assumed was the first time it had been ever opened. 2nd gear came back with a start up. I still ditched it for a zf shortly after for the larger clutches available and the torque ratings, and the gear ratios. Lol
  1. Replies: 10
    Last Post: 04-01-2014, 04:09 PM
  2. E36 Parting out 93 e36 325is alpine white II
    By z25is in forum Whole Parts Cars
    Last Post: 08-20-2013, 01:24 AM
  3. E36 93 e36 325is parts
    By 1mume21 in forum Whole Parts Cars
    Last Post: 06-06-2011, 01:51 AM
  4. 93 e36 325is gearing
    By 325IStwinT in forum 1991 - 1999 (E36)
    Last Post: 06-09-2007, 03:05 AM
  5. Will these fit on my 93 e36 325is?
    By Bengali86 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-02-2004, 04:33 PM
